Sound problems like crackling MAXIMUS XI CODE
GiJoe_83
hi,
I've some problems like crackling withe the motherboard,
I've try to Enable MSI (Message Signaled-based Interrupts), in vain,
if somebody have a solution,
14 REPLIES 14
kens30
Level 11
Disable windows hibernation (not needed for ssd) by running this command in cmd.
Run CMD as admin and type powercfg -h off press enter and now restart for it to take effect.
See if that fixes your issue.
If the issue persists check out this thread to update your sound drivers
https://rog.asus.com/forum/showthread.php?105341-DRIVERS-Realtek-HD-Audio-(UAD)
ok, i will try this, thank you !
i have always the same problem
i've try old drivers, new drivers, uninstall and reinstall, active msi function, in vain...
Retired
Not applicable
GiJoe_83, I had almost the same problem like yours for quite a while. Try accessing your BIOS and disable option Hot Plug in Sata Configuration. See if it works.
hot plus is already disable,
GiJoe_83
Rockford wrote:
disable windows hibernation and hotplug for audio crackling problems?
:rolleyes:
i try this two, and nothing
Your audio problems might be installed driver/software related.
Try running LatencyMon 6.70 to check if that's the case.
home page
https://www.resplendence.com/latencymon
download
https://www.resplendence.com/download/LatencyMon.exe
home page
download
i've try to uninstall audio software, update drivers on asus and on this forum and nothing work
i'll try this immediatly
