Results 1 to 10 of 11
02-18-2019 10:15 AM #1
- Join Date
- Jun 2013
- Reputation
- 10
- Posts
- 33
Rampage VI Omega VRM Fans NOt turning off Despite below 60C VRM Temps!
Does anyone know how to get these little fans to turn off? VRM is 45C and they are still on and even in the bios when I set to 0 RPM it doesn't work along with the temp limits!!!!
They are constantly on at 11% and this is very annoying. What I should have clairified is 11% is the lowest they go instead of zero.Last edited by nyxagamemnon; 02-18-2019 at 11:08 AM.
02-18-2019 10:56 AM #2
1. Can you confirm the UEFI version?
2. Do the fans work ok on Auto?
3. Have you attempted to adjust the fan curve?
02-18-2019 11:03 AM #3
- Join Date
- Jun 2013
- Reputation
- 10
- Posts
- 33
02-18-2019 11:13 AM #4
02-18-2019 11:35 AM #5
- Join Date
- Jul 2011
- Reputation
- 103
- Posts
- 790
02-18-2019 12:14 PM #6
- Join Date
- Jun 2013
- Reputation
- 10
- Posts
- 33
1. Header is in place no issue
2. IN the bios I can goto ez mode set to 0 fans will turn off works as normal.
3. In AI Suite fans don't go below 11% Bios it goes to 0. I have the only version from the Website that's listed under the OMEGA. The Bios curve and AI suite curve are Not the same!.
Ai Suite version is Version 3.00.36 2019/01/04160.61 MBytes
-AISuite3
-ASUS AI Suite 3 V3.00.36 Install Program for Windows 10 64-bit.
-DIP5 -ASUS Dual Intelligent Processors 5 V1.06.67 for Windows 10 64-bit.
-PC Cleaner -ASUS PC Cleaner V1.06.67 for Windows 10 64-bit.
-EZUpdate -ASUS EZ Update V2.03.20 for Windows 10 64-bit.
https://i.imgur.com/n4IIXmq.png
Case in point red bar = 11% Fan says can go 0-100%
But to have Shamino respond hahaWould never have guessed you would!
02-18-2019 12:17 PM #7
- Join Date
- Jun 2013
- Reputation
- 10
- Posts
- 33
I can adjust the curve from F7 EZ mode and it will work but the curve isn't the same in AI suite won't go below 11%. BTW guys the auto fan tuning is the stupidest thing ever I hate it. I just want full control of 0-100 without "Auto tune that limits my range so much" For the love of god allow a power user to set whatever percentage we want and not Auto tune it via AI Suite 3. I miss that from the old Rampage V Extreme. I don't need it to limit my lower range if I want to run my fans at less than X percentage. I believe the auto tune screwed it up and won't let it goto 0 to turn it off.
I uninstalled the AI suite and fans are not coming on and following the bios curve and it seems ai suite is the problem. Yeah so I can't put my CPU fan in "Extreme quite mode unless I run Auto tune which then screws up the VRM heatsink fans and makes them not goto 0 and down to 11% as the lowest.. Lol
Seriously just allow full 0-100% control for the user as a default and then let them run auto tune. If they want I think I can manage to set my fan speeds if I can build a custom loop and a pc from scratch.....
So Just install the AI suite on the motherboards page hit auto tune and watch it never turn off and not allow you to go below 11%
Please fix!
**Update** So I shut the pc down unplugged the CPU Fan put it on an aquero and now for some reason the vrm fans are not stuck at 11% but the red line is @ 11% but there off? So yeah there is something buggy going on with AI suite.
**Another update** never mind the top update it's bugged out still
https://i.imgur.com/kuAqLpF.png
Lol the dot is in two places 0 and 11% but as you can see it's running at 11% (Ignore the cpu 0000 I moved it off the header.Last edited by nyxagamemnon; 02-18-2019 at 01:25 PM.
03-15-2019 05:46 AM #8
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 30
I also have the same problem, I cant get the RPM of the VRM fans below 11 percent, no matter how low the temperture. everything below 11 percent is red for the curve, so it does not let me adjust it downward to 0
02-15-2021 01:10 PM #9
EazyRyder PC Specs Motherboard ASUS RAMPAGE VI APEX X299 Processor INTEL I9 7900x Memory (part number) 32GB DDR4 3333MHZ CORSAIR VENGEANCE RGB (CMR32GX4M4C3333C16) Graphics Card #1 ZOTAC GTX 1080ti AMP EXTREME Monitor ASUS MG279Q 1440P/144HZ GAMING MONITOR Storage #1 SAMSUNG 850 EVO 500GB SSD Storage #2 SAMSUNG 850 EVO 1TB SSD & WD CAVIAR BLACK HDD 2TB CPU Cooler CORSAIR HYDRO H150i PRO RGB 360MM AIO COOLER Case PHANTEKS ENTHOO PRIMO REV 2 Power Supply EVGA SUPERNOVA 850 G2 Keyboard NANOXIA NCORE RETRO MECHANICAL Mouse Tt eSPORTS LEVEL 10 M ADVANCED LASER GAMING Mouse Pad AULA VARANUS KOMODODENSIS Headset/Speakers CREATIVE GIGAWORKS T40 SERIES II OS WINDOWS 10 PRO
- Join Date
- Aug 2015
- Reputation
- 10
- Posts
- 4
03-08-2022 06:03 PM #10
- Join Date
- Mar 2022
- Reputation
- 10
- Posts
- 1
Solution setting the HS Fan to Silent.
Do this only when you know what you are doing!!
Solution:
-Exit AI Suite.
-Go to:
C:\ProgramData\ASUS\DIP\FanXpert\FanCalibrationDat a.xml
-Find <name>HS_FAN</name> in the XML file.
-Change <maxdutytokeepstill>11</maxdutytokeepstill> to
<maxdutytokeepstill>0</maxdutytokeepstill>
-Save the XML file.
-Start AI Suite.
That's it.
