Results 1 to 3 of 3
    ROG Member Array
    Sep 2015
    13
    PG279Q Popping Noise?
    Hello All
    Is it normal for a monitor to make a popping noise? it happens on my PG279Q Gsync Monitor every hour or so there is no visual defects or display loss so I wonder if it might be thermal expansion?
    ROG Guru: Green Belt Array UltraNEO* PC Specs
    UltraNEO* PC Specs
    Laptop (Model)Dell XPS 13
    MotherboardAsus Rampage V Edition 10
    ProcessorIntel i7-6850k
    Memory (part number)G.SKILL F4-3600C17Q-32GTZR
    Graphics Card #1Titan X (Pascal)
    Graphics Card #2Titan X (Pascal)
    MonitorASUS ROG Swift PG279Q (x3)
    Storage #1Samsung 970 Pro 1TB NVMe
    Storage #2Samsung 860 Pro 1Tb (x4)
    CPU CoolerCustom Watercooled
    CaseCaseLabs SMA8
    Power SupplyCorsair AX1500i
    Keyboard Keyboard Paradise Custom
    Mouse Logitech G903
    Mouse Pad Logitech G840 XL
    Headset/Speakers ART SLA2 Linear Amp with JBL Control 5
    OS Win 10 Pro
    Network RouterPF Sense
    Accessory #1 Logitech Brio 4k
    Accessory #2 Logitech PowerPlay Game Pad
    UltraNEO*'s Avatar
    Dec 2011
    28
    582
    How are you connecting the monitor to your system? It does have internal speakers, that might create some sound..
    ASUS ROG RVIE Omega | i9-9980xe | Dominator Platinum 128GB 3333 MHz | EVGA RTX 2080 Ti SLI | Samsung 970 Pro 1TB NVMe (x3)
    WD Black 4TB x2 | WD Black 6TB | Corsair AX1200i | CaseLabs SMA8 | Custom Water Cooling | HWLabs Black Ice Nemesis GTX 560
    XSPC RX 480 v3 | XSPC D5 Vario x2 | EK Blocks | EK-RES X3 400 | BitsPower Fittings | GentleTypoon 1850 x12 | Corsair SP140 x8 | Lamptron CM615
    Twitch.tv/MsNikita | Twitter.com/MsNikitaTV | Instagram.com/MsNikitaTV | Reddit.com/r/MsNikitaTV
    ROG Member Array
    Sep 2015
    13
    Quote Originally Posted by UltraNEO* View Post
    Connecting the Display port cable to my 1080 ti and ac power adapter to a surge protector and using headphones not speakers.
