Results 1 to 3 of 3
    New ROGer Array
    Feb 2019
    1
    Advice on Upgrading my system
    Hello guys , I'm looking for some advice from you . I'd like to upgrade my current system , I built this PC back in 2010 /2011 , and still nowadays is a very performant PC , So I hope with the info I'm sharing here , you guys would be able to advise me which components I'd have to replace or upgrade in order to make it more performant if possible , I have thought maybe the processor would be a good idea but I don't know which one is superior to the one I have already , RAM also if someone can guide me which ones can be installed in my Mainboard , anything that can be upgraded guys I'd like to hear it .
    Also if youy can share with me sites where I can buy this components , I'm in Canada .
    Thanks in advance for your kind attention.
    Processors Information
    Socket 1 ID = 0
    Number of cores 4 (max 4)
    Number of threads 8 (max 8)
    Name Intel Core i7 950
    Codename Bloomfield
    Specification Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
    Package (platform ID) Socket 1366 LGA (0x1)
    Memory SPD
    DIMM # 1
    SMBus address 0x50
    Memory type DDR3
    Module format UDIMM
    Manufacturer (ID) Kingston (7F98000000000000000000)
    Size 2048 MBytes
    Max bandwidth PC3-10700 (667 MHz)
    DIMM # 2
    SMBus address 0x51
    Memory type DDR3
    Module format UDIMM
    Size 4096 MBytes
    DIMM # 3
    SMBus address 0x52
    Memory type DDR3
    Module format UDIMM
    Size 2048 MBytes
    DIMM # 4
    SMBus address 0x53
    Memory type DDR3
    Module format UDIMM
    Size 4096 MBytes
    DIMM # 5
    SMBus address 0x54
    Memory type DDR3
    Module format UDIMM
    Size 2048 MBytes
    DIMM # 6
    SMBus address 0x55
    Memory type DDR3
    Module format UDIMM
    Size 4096 MBytes
    Monitoring
    Mainboard Model Rampage III Extreme (0x000006B2 - 0xF3837805)
    DMI BIOS
    vendor American Megatrends Inc.
    version 1502
    date 10/03/2011
    ROM size 2048 KB
    D
    DMI Processor
    manufacturer Intel
    model Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
    clock speed 3066.0 MHz
    FSB speed 133.0 MHz
    multiplier 23.0x
    Graphics
    Number of adapters 1
    Graphic APIs
    API D3D
    API NVIDIA I/O
    API NVIDIA NVAPI
    Display Adapters
    Display adapter 0
    ID 0x1070107
    Name NVIDIA GeForce GTX 750
    Board Manufacturer ASUSTeK Computer Inc.
    Revision A2
    Codename GM107
    Core family 0x117 (GM107)
    Technology 28 nm
    Memory size 1024 MB
    Memory type GDDR5
    Memory vendor Hynix
    PCI device bus 3 (0x3), device 0 (0x0), function 0 (0x0)
    Vendor ID 0x10DE (0x1043)
    Model ID 0x1381 (0x84AD)
    Revision ID 0xA2
    Performance Level 0
    Core clock 1058.0 MHz
    Memory clock 2505.6 MHz
    Software
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
    DirectX Version 11.0
    ROG Guru: Green Belt Array UltraNEO* PC Specs
    UltraNEO* PC Specs
    Laptop (Model)Dell XPS 13
    MotherboardAsus Rampage V Edition 10
    ProcessorIntel i7-6850k
    Memory (part number)G.SKILL F4-3600C17Q-32GTZR
    Graphics Card #1Titan X (Pascal)
    Graphics Card #2Titan X (Pascal)
    MonitorASUS ROG Swift PG279Q (x3)
    Storage #1Samsung 970 Pro 1TB NVMe
    Storage #2Samsung 860 Pro 1Tb (x4)
    CPU CoolerCustom Watercooled
    CaseCaseLabs SMA8
    Power SupplyCorsair AX1500i
    Keyboard Keyboard Paradise Custom
    Mouse Logitech G903
    Mouse Pad Logitech G840 XL
    Headset/Speakers ART SLA2 Linear Amp with JBL Control 5
    OS Win 10 Pro
    Network RouterPF Sense
    Accessory #1 Logitech Brio 4k
    Accessory #2 Logitech PowerPlay Game Pad
    UltraNEO*'s Avatar
    Dec 2011
    28
    582
    May I ask, what is the primary uses of this system? I mean, what do you do with it?
    I'm asking because our advice can vary from minor upgrades to a full-on new system upgrade/build.. and you as the user, might not use your computer to play the latest games. Therefore the latter of this would mostly be a waste of money. If you get what I mean.
    ASUS ROG RVIE Omega | i9-9980xe | Dominator Platinum 128GB 3333 MHz | EVGA RTX 2080 Ti SLI | Samsung 970 Pro 1TB NVMe (x3)
    WD Black 4TB x2 | WD Black 6TB | Corsair AX1200i | CaseLabs SMA8 | Custom Water Cooling | HWLabs Black Ice Nemesis GTX 560
    XSPC RX 480 v3 | XSPC D5 Vario x2 | EK Blocks | EK-RES X3 400 | BitsPower Fittings | GentleTypoon 1850 x12 | Corsair SP140 x8 | Lamptron CM615
    Twitch.tv/MsNikita | Twitter.com/MsNikitaTV | Instagram.com/MsNikitaTV | Reddit.com/r/MsNikitaTV
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,464
    How much money you plan to spend for PC?
    That's most important part.
    I can't wait new DDR5 platform to build new desktop PC.
    Off course I would like earlier but it's not real because budget.
    I think that will be my strongest PC I ever build. I plan to pay around 1500 euro maybe few euro more for CPU-Mobo-RAM.
    Plan is Intel 10 core, 32-48GB memory Dominator Platinum RGB DDR5 4400MHz+ depend of Quad Channel or Six Channel and Rampage motherboard.
    I'm very disappointed because we still pay Intel Core who can't compete with AMD Zen core and that was obvious on server market and processor with more cores where Intel can't keep high frequency to compensate older architecture.
    What Intel done, launch 28 core CPU worth 4000$ with six channel IMC to compete to AMD, Intel Xeon Server vs AMD Threadripper 2 32 Desktop.
    And to beat him ASUS helped him with half meter long VRM section capable to resist overclocking CPU and 1000W power consumption.
    Total price of platform 7000$ together with memory. I still see slower some benchmarks than Threadripper platform worth 3000$. 2990-Zenith-Extreme-RAM.
