Results 1 to 8 of 8
    ROG Member Array
    Feb 2019
    5
    Audio stutter partially solved
    Hi everybody. I have audio stutter issue on my am4 system witch i had on my last am3 system but was solved with bios update
    Specs: Asus prime b450m-a with latest bios
    Ryzen 2600x
    8gb rgb hyperx 2933
    gtx 1060 6gb
    240 gb SanDisk pro ssd
    My issue is that i have random pops in audio for both onboard and usb headset like crackles or something. I can reproduce it 100% by for example streaming music from deezer and at the same doing repair of game (albion, or anny battlenet game). Other times its random.
    I did few things to try and fix it.
    Disabled fastboot in windows.
    Disabled fastboot in bios.
    Clear CMOS
    Disabled onboard lan and audio.
    Uninstalled nvidia driver
    Disabled nvidia driver and enabled it after
    Changed psu
    Switched to different wall outlet
    switched usb headset in every port with drivers and without them
    turned xmp for ram on or off
    disabled all cstates in bios and setting max performance in windows
    but nothing has realy helped.
    By accident i stumbeled on workaround. To get stutter free audio i disabled fast boot in bios and every time before i get in windows i just have to enter bios(dont need to change anythin) and hit save and exit. It works every time. I have no idea what does entering bios and rebooting trigger but it works.
    If any of you have an idea how to fix it completely i would be grateful. thx
    ROG Guru: Blue Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(3) SSD's - Samsung 960 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    45
    982
    This is far out but do you have any USB devices plugged in? I get periodic stutters in apps which I think is because of USB mouse and USB KB.
    Davemon50
    ROG Member Array
    Feb 2019
    5
    Quote Originally Posted by davemon50 View Post
    Thx for reply.
    I have razer naga and cooler master mech keyboard. Nothing else. Just now i tried all possible combinations of pluging them off and rebooting but still that method of scanning integrity of game and streaming audio will throw pops in sound(that is the only method im shure of it will stutter in games later on).
    Whats strange to me is that i just have to enter bios before boot and save and exit and all will work just fine every time. this is driving me nuts.
    ROG Member Array
    Feb 2019
    5
    one thing i noticed is that it doesnt happen from cold boot. like if i turn off psu and leave it 30 sec then turn on its fine regardles of me enterinf bios or not
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    45
    982
    To me, based on what you've tried and the fact that restarting fixes the issue, I would suspect a software conflict. Something that is loading or a service that is initiated would be my suspicion. Troubleshooting software conflicts can be very time consuming but might be where you need to go next. You can try the major things first, like startup programs, and move on to other items you start while you are working.
    Davemon50
    ROG Member Array
    Feb 2019
    5
    We misunderstood eachother. It happenes on regular pc restart. It doesnt happen if i plug out my pc from power and leave it like that for few minutes.
  7. #7
    ROG Guru: Orange Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD Samsung 960 EVO 256GB
    Storage #2SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 Pro 64 bit
    MoKiChU's Avatar
    Aug 2013
    87
    304
    Can you try this :
    - Interrupt Delivery Mode : Full MSI (Message Signaled-based Interrupts) with MSI Utility : https://github.com/CHEF-KOCH/MSI-uti...eleases/latest
    - Fast Startup (Windows) : Disabled (by disabling Hibernation in cmd as administrator : powercfg.exe /hibernate off)
    - Fast Boot (BIOS) : Enabled
    - CSM (BIOS) : Disabled (Full UEFI)
    - Secure Boot (BIOS) : Windows UEFI Mode
  8. #8
    ROG Member Array
    Feb 2019
    5
    Quote Originally Posted by MoKiChU View Post
    Can you try this :
    Thx for suggestion. All of those things are done except full MSI. Tried deleting safe boot key witch installed by default and tried with it installed safe booting. Before i trie Full MSI i have 2 more things to do. Tracked performance of my pc during stutter triger(with windows recording tool) and it seems windows defender process whas spiking at the same time first pop happens. For now i installed avast witch reduced poping amount by alot. I mean i can disable defender by itself but i prefer to have some kind of protection. Il trie for few days to confirm. Iv got another suspect witch is my ssd. My buddy has one laying around and il trie to install windows on it and see what happens. Thats the only part of pc that wasnt changed. As i said same thing happened on my old am3 system witch had same ssd and was fixed with bios update so i doubt my usb headset is at fault. At that time i blamed windows creator update cause before that it worked fine but i cant exactly remember at witch point i got this ssd. Sorry for confusing post. English is definitely not my primary language.
