Results 1 to 7 of 7
    ROG Guru: Orange Belt Array
    Oct 2013
    34
    258
    Rampage VI Extreme Bios 1704 is Out
    ROG RAMPAGE VI EXTREME BIOS 1704
    - Improve system performance and stability.
    - Fixed RAID card issue.
    - Updated ME FW to ver. 11.11.60.1561
    " Before running the USB BIOS Flashback tool, please rename the BIOS file R6E.CAP using BIOSRenamer.''
    Rampage VI Extreme bios 1503
    Core i9 7980XE @ 4.4ghz all cores
    64 gb Corsair Vengeance RGB Pro 3600
    2x RTX 2080 Ti FE NvLink/SLI
    2x Samsung 970 Pro 1tb NVME
    Corsair AX1600i
    Corsair 1000D case
    1x Dell U3818DW 38" Curved Ultrawide and 2x Dell S2716DG 27" 1ms GSYNC 2560x1440 144 hz
    Win 10 Pro x64
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS x99 sabertooth & x299 Rampage VI Apex
    Processori7-5930k & i9-9940x
    Memory (part number)Trident-Z 3200C14 & Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block & Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Coolerx99 2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 & EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum & Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Heatkiller IV Pro plexi/ Copper base on both systems
    Accessory #2 Mayhems Biocide and Inhibitor with distilled water
    Accessory #3 Mayhems 3/8-5/8" clear soft tubing
    ThrashZone's Avatar
    Oct 2017
    13
    278
    After reading about the borked new Omega bios I'll pass till the dust settles and then some
    Oct 2013
    34
    258
    Would have been nice if Omega was an upgrade. $100 more for half the features. Brilliant. And they try to hide it by deleting posts.
    Corsair AX1600i
    Corsair 1000D case
    Win 10 Pro x64
    ROG Guru: White Belt Array cekeu PC Specs
    cekeu PC Specs
    MotherboardROG RAMPAGE VI EXTREME
    ProcessorIntel® Core™ i9-7900X
    Memory (part number)GSKILL DDR4 32GB (4*8) F4-3200C14Q-32GTZSW
    Graphics Card #1Zotac RTX 2080 Ti AMP Extreme Core
    MonitorASUS ROG SWIFT PG27UQ
    Storage #1SAMSUNG SSD 970 EVO NVMe M.2 1TB
    Storage #2BARRACUDA PRO (8TB) ST8000DM005
    CPU CoolerCORSAIR Hydro Series™ H150i PRO RGB 360mm
    CaseLian Li PC 011 WXC
    Power SupplySeasonic Prime Platinum SSR-1300PD
    Keyboard Corsair Gaming K70 RGB
    Mouse Corsair Scimitar Pro RGB
    Headset/Speakers Edifier Studio® R1800TIII
    OS Windows 10 Pro
    Jun 2013
    121
    After I updated the BIOS 1503 to 1704 The firmware remained at the version 11.11.55.1509 instead of being updated to version 11.11.60.1561 included in the BIOS 1704
    ROG Enthusiast Array thr23 PC Specs
    thr23 PC Specs
    MotherboardAsus ROG Rampage VI Extreme
    ProcessorIntel Core i7-7820X
    Memory (part number)G.Skill Trident Z RGB DDR4, 4x16GB, 3600MHz (F4-3600C17Q-64GTZR)
    Graphics Card #1Asus ROG Strix GeForce GTX 1080 Ti OC
    Storage #1Samsung SSD 960 PRO 1TB
    Storage #2WD Red 10TB
    CPU CoolerNoctua NH-D9L
    CaseIn-Win 805 Red
    Power SupplyThermaltake Toughpower iRGB PLUS 1250W Titanium
    Oct 2017
    28
    30
    Quote Originally Posted by cekeu View Post
    looks like they've added a separate ME updater in the 'Utilities' section.
    Nov 2015
    116
    do you see any files when under drives & tools on the asus website?
  7. #7
    cekeu PC Specs
    OS Windows 10 Pro
    Jun 2013
    121
    Quote Originally Posted by thr23 View Post
    Ok they put it in the utilities, I had not seen. The previous ones were put with the BIOS
    https://dlcdnets.asus.com/pub/ASUS/m...265.1550848271
    Thanks
