Results 1 to 7 of 7
    New ROGer Array
    Feb 2019
    2
    Asus Aura Sync Not Picking up Corsair CORSAIR Vengeance RGB PRO
    Just build my computer and I'm unable to get Aura Sync to detect CORSAIR Vengeance RGB PRO "16GB (2x8GB) DDR4 3200MHz". Corsair iCUE had issue detecting the RGB too but I resolved that issue once I downgrade my BIOS on my Asus Prime X470-Pro to v4024. Now iCUE is able to control the CORSAIR Vengeance RGB PRO lighting effect. However, I want to use just Aura Sync to mange all RGB including the RAM. Has anyone gotten their CORSAIR Vengeance RGB PRO to work with Prime X470-Pro motherboard and Aura Sync app? I've tried latest version of Aura Sync and older version that's available for my board. As an alternative I'm using iCUE to control the CORSAIR Vengeance RGB PRO and Aura Sync for the Motherboard and attached RGB. If anyone had success please share what you did and what software version you had install or configuration done.
    Current Installed BIOS Version: v4024
    Current install Aura Sync version: V1.05.32.02_0329
    ROG Member Array
    Jul 2014
    9
    nope Asus haven't added support yet
    New ROGer Array
    Feb 2019
    2
    Quote Originally Posted by AndersT View Post
    Thanks, I wonder why it’s taking so long. Anyone know if this is just on Prime X470 or same issue on other board?
    ROG Enthusiast Array
    Aug 2018
    61
    you can try JackNet RGB sync to sync all things,
    just be careful because it's considered a third party software
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,465
    Same is with CORSAIR Dominator Platinum RGB. You need to install their software because not work with ASUS Aura.
    That's stupid.
    ROG Guru: White Belt Array
    May 2014
    28
    102
    Quote Originally Posted by tungd00927 View Post
    just released and still does not work with corsair ram of course
    https://dlcdnets.asus.com/pub/ASUS/m...557.1564143631
    Asus Rampage VI Extreme / Intel I9-7940X / Corsair H115i Pro / CORSAIR Vengeance RGB Pro 32GB (4 x 8GB) 3000MHz / EVGA GeForce GTX 1080 Ti FTW3 ELITE GAMING BLACK Edition / 2x Samsung 970 Pro NMVe 1GB / 4x Samsung 850 PRO - 2TB / Asus ROG Swift PG348Q / Corsair AX 1500i / Thermaltake View 71 RGB PC Case /Win 10 PRO x64
  7. #7
    May 2014
    28
    102
Tags for this Thread
