Hello everyone, I would like that one maide about my processor. I find it runs at a high frequency.
Motherboard asus maximus X hero
I7 8700k
DDR4 corsair rgb pro 3200mhz
Alil thermaltake rgb 850w
Gtx 1080 asus strix oc
The procc, resting on the desk turns around 4ghz, nothing open, except the sea ** base win10, corsair icue (stain)
I disable the cpu asus boost rendering in the bios, and enabled the xmp mode of the ram.
That's nothing else.
I would also like to know the way that is used to define if we are falling on a good series of proccessor.
I know that each processor runs differently (procc of the same series)
Know what to do to see if you are good or bad.
Thank you
