Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    ROG Enthusiast Array
    May 2017
    30
    asus rampage vi extreme ram problem
    Hello all. I'm having an issue with my computer. when I put 4 sticks of ram in for quad channel, the computer will randomly hard lock in stress tests, in games, and sometimes even when doing nothing. It runs fine with any combo of ram sticks ( to rule out a bad stick) with 3 in, but as soon as I put 4- i get hard lock ups. Is this a bad board, or bad ram? what does it sound like is the issue? Thank yoU!
    Update- i just tested all 4 sticks running in all the 4 left slots for quad channel, instead of 2 left and 2 right for quad channel. its running fine now, quad channel- even for stress testing. So it seems maybe the ram is fine. In this case, does it sound like its a CPU issue or a motherboard issue? it seems like any time i put more than 1 stick on the right side in any slot, i have crash issues. I cant get it to run quad channel using 2 left and 2 right. Yes I checked the manual to make sure I get them in the correct slots for 4 way quad.
    thank you for any help !
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    304
    Are the 4 sticks from a matched kit? If not this could be your problem or perhaps a bad connection from the CPU to the RAM sockets.
    Are you trying to run OC?
    Which MB?
    Which RAM?
    May 2017
    30
    Quote Originally Posted by G75rog View Post
    Which MB?
    Which RAM?
    asus rampage vi extreme motherboard, newest bios.
    ram is gskill trident z RGB 3200- its 8gb x 4 matching set from a kit.
    problem happens with or without overclock. Runs perfectly fine if they are all on the left slot quad channel, running in quad verified by CPUZ. But any time I try to run 2 left 2 right, ( correct quad channel slots verified by manual) crashes happen, constantly and quickly.
    ROG Guru: Green Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    501
    Hi dandan have you set dram voltage 1.35v ( sometimes needs higher) also vccio try 1.2100v and vccsa 1.175v, it may help? But weird they run on one side only. GSkill run at higher volts.
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS z490 maximus XII Apex 2nd x299 Rampage VI Apex
    Processori9-10900k & i9-9940x
    Memory (part number)Trident-Z 3600c16 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 ModmyMods clear coolant
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    23
    416
    Post to the exact set of memory you have
    Sounds like a dual channel set to me meaning only z-series boards on qvl list.
    ROG Member Array
    Jun 2015
    17
    Quote Originally Posted by dandan112988 View Post
    It happens to a lot of people including me. Putting 4 memory sticks into the slots on the right side causes crashes on stress tests and freezes on normal usage. Putting memory on the left side - stress tests passes perfectly. I've heard this story so many times with this mainboard that I'm 100% sure that this is a ASUS problem - not the CPU or memory. If you find any solution, please share on this forum. I have a big problem as I have 8 memory sticks and I can use only 4 of them.
  7. #7
    Rob W. PC Specs
    Sound Cardonboard?
    OS Win 10
    Dec 2015
    104
    501
    Hi rython, I’m using all 8 slots ( 8x8gb ddr4 3600hzs *GSkill rgb ) quad channel,they are running at 3800hzs 15-15-15-34 stable.
    I have noticed in bios channels a,b voltages slightly differ from channels c,d ie; left slots run at a higher voltage (right=1.35 left=1.36)?
    Latest bios caused an upset for them and I had to reseat them but now they are fine at 1.37v or 1.38v, vccsa at 1.10v and vccio at 1.150v,I also set in dram timing to train (enable).
    I think it is a board issue between the two sides that needs tweaking? Causing instability.
  8. #8
    May 2017
    30
    Quote Originally Posted by rython View Post
    I did not find a solution. I just RMAed my board yesterday. I have heard horror stories of RMA, im worried to get an even worse board back. Mine went in flawless.
  9. #9
    ROG Member Array
    Dec 2018
    23
    Changes I made to fix the problem, please note your timing and frequency will depend on your memory. Let me know if this helps you!!!
    Dram Frequency (3200)
    Dram CAS# (16)
    Dram RAS# to CAS# (18)
    Dram RAS# Pre Time (18)
    Dram RAS# ACT Time (36)
    Receiver DQ Pre-Emphasis (0.700000)
    Receiver DQ De-Emphasis (1.171875)
    Transmitter DQ Pre-Emphasis (1.171875)
    Transmitter DQ De-Emphasis (1.171875)
    Enhanced Training CHA (Enabled)
    Enhanced Training CHB (Enabled)
    Enhanced Training CHC (Enabled)
    Enhanced Training CHD (Enabled)
    Dram Voltage CHA, CHB (1.3500)
    Dram Voltage CHC, CHD (1.3500)
  10. #10
    ROG Member Array
    Jan 2018
    21
    Thank you!!!
    OMG, you have just saved me from months of stress!! I have a Rampage VI Extreme board, and have spent months trying to get 64GB DDR4 stable. I could never get the RAM stable at all, let alone its rated 3000mhz. I tried everything, buying new RAM, trying different voltages, but stupidly never trying to move the DDR4 from the recommended manual configuration. Having accidentally come across this post, I tried what you have suggested. Moving all four modules over to the left hand bank of slots. Lo and behold, all stable!! How daft is that, must be some bizarre quirk of this board!
