Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Build advice.
    ROG Guru: Yellow Belt Array rog-classified's Avatar
    Jan 2013
    17
    135
    Build advice.
    Hi, my Titan xp cards just died due to a water leak and i didn't put attention on the cards. Need a good 2080 ti card, do you guys know ROG-MATRIX-RTX2080TI-P11G-GAMING card, when it is available or where to buy or order? If not what is the best 2080 ti card in the market? I am out of touch these days. My monitor is Asus rog swift curved pg348q, 3440X 1440. Do you guys think a one 2080ti card can handle this or do I have to go SLI? Thank you.
    It ain't over till the fat lady sings ...
    Jan 2013
    17
    135
    Quote Originally Posted by rog-classified View Post
    one card dead and other is giving error cord 43.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    If you are going to water cool, make sure there are blocks available specifically for the card if you purchase a manufacturer custom card, if purchasing a card based on Nvidia's card a block should be easier to find. If not water cooling a custom card like the one you mentioned or similar will work fine and a single card will more then handle the resolution of your monitor or even 4K
    ROG Guru: Green Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    501
    I’m running a 4k pa329q off the NV rtx2080ti FE, single card handles monitor with every setting on ultra.
    Sorry to hear your *cards died.*
    Jan 2013
    17
    135
    Quote Originally Posted by Menthol View Post
    Thanks Menthol. I will go for evga 2080ti ftw3, Asus strix 2080 ti or MSI lighting. what do you recommend? Seems like Asus rtx 2080 ti matrix is not out yet. Im on GTX 680 now
    Jan 2013
    17
    135
    Quote Originally Posted by Rob W. View Post
    Thhanks Rob. I have to wait for matrix or get a one is available now. I always had FPS issues with my Asus rog swift curved pg348q even with Titan Xp SLI. Hope Rtx 2080ti can handle this.
  7. #7
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,548
    If you can wait for the card you want OK, if not EVGA always has good products
    I also run 2 32 inch 4K Benq monitors without any issues on a single 2080ti
  8. #8
    Jan 2013
    17
    135
    I am trying to get information about the product launch, if its near i will wait, if not will go with other cards. Thanks.
  9. #9
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,119
    i recomend to read up on evga's warranty ( or every one that you have in mind ) to see what they can do when it comes to custom WC and warranty.
  10. #10
    ROG Member Array Lunatic24_7 PC Specs
    MotherboardASUS ROG MAXIMUS XI EXTREME
    ProcessorINTEL CORE i9 9900K 3.6GHz
    Memory (part number)T-FORCE NIGHTHAWK RGB 32GB
    Graphics Card #1Gigabyte Aorus 2080Ti Extreme
    MonitorACER PREDATOR Z35
    Storage #1SAMSUNG 970 EVO PLUS M.2 500GB
    Storage #2T-FORCE DELTA RGB SSD 500GB
    CPU CoolerASUS RYUJIN 360
    CasePHANTEKS EVOLV X
    Power SupplyASUS THOR 850W PLATINUM
    Keyboard RAZER DEATHSTALKER
    Mouse ASUS ROG SPATHA
    Headset ASUS ROG CENTURION 7.1
    Mouse Pad RAZER FIREFLY RGB
    OS WINDOWS 10 PRO x64
    Accessory #1 ASUS AURA CONTROLLER
    Accessory #2 NZXT INTERNAL USB HUB
    Accessory #3 CABLEMOD PRO MODMESH CUSTOM CABLING
    Lunatic24_7's Avatar
    Feb 2019
    9
    Unhappy Matrix 2080Ti...still waiting!
    I have two builds (AMD and INTEL) starting Saturday (2/3/19) and have put off purchasing a 2080Ti for one, until I see the pricing on the Matrix edition...Asus stated the the Matrix card would be available in January at CES, then it was changed to February in their press release...and now its 25 minutes to March....I feel like this card is a MYTH!
    It would be nice to even have an inkling about roughly its due date...if a games developer were to do the same regarding a game release, the entire gaming community would be up in arms!
Tags for this Thread
