Results 1 to 4 of 4
    ROG Member Array hill160881 PC Specs
    hill160881 PC Specs
    MotherboardMaximus xi formula
    ProcessorI5-9600k
    Memory (part number)corsair 4x8 2666mhz
    Graphics Card #1gtx 1070
    Graphics Card #2haha no
    Graphics Card #3still no
    Graphics Card #4and still no
    MonitorSamsung 49'(32x9) super ultra wide 1080 at 144hz
    Storage #1samsung 960 evo nvme 250gb
    Storage #2OWC 1 tb pcie ssd
    CPU Coolercustom loop
    Casegarbage pos cougar panzer evo
    Power Supplyevga 850 G2 80+ gold
    Keyboard cheap rgb trash
    Mouse same as the mouse
    OS windows 10 home
    Network Routersome asus thing that was fast a few years ago
    hill160881's Avatar
    Jan 2019
    12
    Maximus xi formula I5 9600k overclocking help! Anything over default not stable
    I am new to asus and newer system overclocking. I am familiar with the terms from the older gigbyte x58 platform as its a very satisfying chip to overclock.
    System is
    Maximus XI Formula
    850 watt gold psu
    I5-9600k
    32gb 2666mhz ram
    gtx 1070
    nvme boot drive
    Cooling is a very simple loop including the VRAM. 360mm rad with 6 fans in push pull. Temps are hard to tell as the different softwares give out different readings. Not over 85c(75avg) at 5.2ghz, cooler score between 178-198 in bios depending on room temp. Not over 60c(50avg) at default speeds.
    Cooling loop
    Ekwb cpu block
    Ali copper 360mm rad
    Ali resivour
    Cheap uxcell aliexpress pump
    Cheap xspc barbed fittings \
    Ekwb 3/8 tubing
    I do have a 240 aio but it does not cool the vram so I went with a custom loop. All in all it has more than enough flow and is plenty cool.
    I am not familar with asus bios nore how to overclock on newer systems. Every time I set it to 5.0ghz I start getting prime95 hardware failures. So far I have tried the AI tuner and the preset 5.0 and 5.2 settings but neither are stable.
    Is there a video or thread explaining the different bios settings and what settings are connected to others. like core voltage and cpu pll. That is just an example.
    I would like to run at or over 5.0ghz. This chip is not very hot so I want to push it. I do game a little on my 49" super ultra wide. Not a gamer but this thing is really awesome so now I do enjoy gaming more. mostly I do video editing, so it has to be stable and not have hardware failures nore rounding errors in prime 95.
    Any first hand help, advice or links to other threads would be great as I found nothing with a search on "9600k" in the forum search tools. There was also nothing on this series board or the z390 in the stickies.
    I do plan to upgrade to a 9900k now that my editing system is slowly going out of date. So long apple! But until I pull the trigger on the new 9900k I want to learn to manually OCing these newer chips on a less expensive chip.
    Thanks again!
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,822
    What other settings are you changing besides the multiplier?
    Set Adaptive Mode for Vcore and set between 1.25 - 1.3v in the Additional Turbo Voltage field.
    hill160881 PC Specs
    ProcessorI5-9600k
    OS windows 10 home
    hill160881's Avatar
    Jan 2019
    12
    I will have to take a look at and record all the bios settings for the 5.2ghz presets after work. Thanks for the response!
    hill160881 PC Specs
    ProcessorI5-9600k
    OS windows 10 home
    hill160881's Avatar
    Jan 2019
    12
    I think i have it figured out. The predicted cpu voltage for 5.1ghz was 1.415v and setting the cpu voltage there would result in 1.38-1.39 volts under load at level 6 load line calibration. So I had to upp the load line calibration to 7 and increase the cpu core voltage to 1.455v. Now under full load it does not go below 1.4120v under full load.
    After 1 hour on prime 95 it got really hot a few times and one core ran up to 95c with an average across all cores of 85c. AIDA64 ran for 1 hour with a max temp of 70c and an average of 60c.
    No more crashes, no more throttling, no more hardware failures and no more rounding errors.
    These are the settings I changed after restoring to optimized defaults.
    Extreme tweaker screen
    -XMP 1
    -AVX offset 3 or 4
    -sinc all cores at 5.1ghz
    In the external digi power control screen
    -Load line calibration 7
    -CPU current capability 170%
    In the CPU power management screen
    Long duration package power limit 4095 maxed out
    Package power time window 127 maxed out
    Short duration package power limit 4095 maxed out
    Extreme tweaker screen again
    -CPU core cache current limit max 255.75 maxed out
    -min cpu cache ratio 43
    -max cpu cache ratio 43
    -CPU core voltage override 1.455v
