02-25-2019 05:05 AM - last edited on 03-06-2024 08:41 PM by ROGBot
02-25-2019 05:40 AM
02-25-2019 06:09 AM
LiveOrDie wrote:
When using adaptive or offset voltages you have account for vdrop setting LLC to a high level will reduce the amount of voltage drop, be sure to check you core voltages in a program in windows to see what there actually are because they will fluctuate up and down.
If the board has VRM while i would return it are you sure its the board and not the 2080TI?
02-25-2019 09:58 AM
02-25-2019 11:09 PM
