Results 1 to 3 of 3
    ROG Enthusiast Array carlosriosness PC Specs
    MotherboardIX Formula
    Processor7700k delid
    Memory (part number)G.Skill TridentZ 3200 RGB 32GB
    Graphics Card #11080ti Hybrid
    MonitorLG 65C6P OLED
    Storage #1960 Evo x 2 (raid 0)
    Storage #2950 Evo x 2 (raid 0)
    CPU Coolerh100i
    CasePhanteks Evolv TG
    Power Supplyhx850i
    Keyboard logitech k830
    Mouse G602
    Headset HD6XX with ModMic 4.0
    Headset/Speakers Yamaha 1070 soundbar
    OS Windows 10 Pro
    Network RouterNetgear Nighthawk X4
    Accessory #1 Xbox one elite controller
    Accessory #2 Noctua a12x15 x 7
    Accessory #3 modmymods custom top panel
    Oct 2013
    35
    Unhappy Aura and Phanteks Halo RGB - calibration issue
    Hello,
    i have a couple phanteks halo fan attachements daisy chained along with the single LED in the Phanteks shift case.
    they are all connected to the single rgb header on my Z390i motherboard.
    i open the software and go to the calibration tool. when i start the calibration it says i should be seeing red, but my halos are purple. no matter what i try i cant get them to turn red, blue or green in the calibration. so they are off when trying to sync with the rest of the system.
    what am i missing?
    IX Formula and Z390i
    CPU Coolerh100i
    Power Supplyhx850i
    Mouse G602
    OS Windows 10 Pro
    Oct 2013
    35
    Solution. disable the cases RGB controller (phanteks shift)
    1 - unplug the rgb cable from the motherboard rgb header.
    2 - plug a sata power cable to the cases sata port (this would be used if using the case button to cycle through rgb modes)
    3 - hold case rgb button down for 5 seconds (the rgb light(s) will turn off, this means the built in controller is now off)
    4 - remove sata power
    5 - plug rgb cable back into motherboard header
    6 - go back to asus aura sync software and run calibration tool again!
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    17
    1,717
    Quote Originally Posted by carlosriosness View Post
    excellent. i will pass these to a friend o mine that just spend 8000 grand with with almos the same specs as yours and was on his way to RMA de z390 code like mine
    Learn, Play Enjoy!
