Results 1 to 3 of 3
    ROG Member Array purekaoz777 PC Specs
    Laptop (Model)G752VY
    MotherboardMaximus XI Code
    ProcessorIntel i9 9900k
    Memory (part number)Corsair CMW32GX4M2C3200C16
    Graphics Card #1Asus Strix 1080 ti
    Storage #1Samsung PRO 970 NVMe M.2
    CPU CoolerEK Velocity RGB Full Nickel Waterblock
    CasePhanteks Evolv x
    Power SupplyAsus ROG Thor 1200p
    Keyboard Asus ROG Claymore Cherry Red
    Mouse Asus ROG Spatha
    OS Windows 10 PRO x64
    Accessory #1 EK GPU RGB Waterblock
    Accessory #2 EK XRES D5 RGB pump combo
    Accessory #3 Thermaltake Riing Plus 12
    Apr 2013
    20
    Split addressable RGB header?
    Hey guys, I currently finished building my new computer, however I am in a bit of a conundrum. I have the Asus ROG Maximus XI Code motherboard that has 2 3-pin addressable RGB headers however I have 3 addressable RGB products that I want to plug in.
    Currently connected into my 2 headers are;
    A-RGB Header 1: Phanteks Evolv X case lighting
    A-RGB Header 2: Thermaltake TT Sync Controller with 5 Thermaltake Riing Plus fans connected to the controller.
    My third A-RGB product is the Asus ROG Thor 1200P.
    My research suggests that you can't plug in a 3-pin A-RGB cable into the regular 4-pin RGB header since it will blow it up. Source: https://www.youtube.com/watch?v=zu9mikz9zpQ
    Also, most of the splitters I've found only work for A-RGB identical fans. Such as the Cooler Master A-RGB splitter, http://www.coolermaster.com/cooling/...plitter-cable/
    So is there a way to split an A-RGB header into two with two differing products?
    Or is there another way for me to do this?
    Thanks in advance!
    ROG Guru: Orange Belt Array 1mluer PC Specs
    1mluer PC Specs
    MotherboardMaximus IX Apex & Maximus XI Apex's
    ProcessorI7-7700k & I9-9900k
    Memory (part number)Gskill Trident Z RGB 4266 & 3200 DC
    Graphics Card #1MSI Sea Hawk 1080 & ROG Matrix 2080 ti
    Sound Cardbuilt in for both
    MonitorSamsung 27inch & ASUS Swift PG348Q
    Storage #1Samsung 960 Pro & Samsung 970 Pro
    CPU CoolerRyuo 240 & Ryujin 360
    CaseInWin 909 Black & InWin 909 Silver
    Power SupplySeasonic 1000w Titanium & ROG Thor 1200p
    Keyboard Corsair K95 & ASUS ROG Claymore
    Mouse Logitech G902 & ASUS Gladius II Origin
    Mouse Pad Corsair MM800 & ASUS ROG Baltheus
    Headset/Speakers Bose Computer Set with Sub
    OS Windows 10 Pro all around
    Network RouterLinksys EA 9500
    Accessory #1 Corsair LL / Commander Pro & TT Riing Plus
    Accessory #2 Blue Microphone
    Feb 2017
    33
    306
    Check this out. It should help.. Just make sure your 4pin RGB cable has the key on it and you are safe. you can use a splitter cable that accommodates your connections at both ends. Let me know if you still have any questions.
    https://rog.asus.com/forum/showthrea...k-like-you-ask
    Inwin 909 Black RGB build
    i7-7700k
    ROG Maximus IX Apex
    1080 Sea Hawk
    InWin 909 Silver RGB build
    i9-9900k
    ROG Maximus XI Apex
    ROG Matrix 2080 ti
    Gskill TridentZ RGB DC 3200 64g
    Everything overclocked and love it.
    ROG Awesomeness !!!!
    ROG Member Array paru055 PC Specs
    paru055 PC Specs
    MotherboardAsus Rog Ramapage Extreme vi
    ProcessorIntel i9 7900x
    Memory (part number)Corsair Vengence Pro 2666 64 GB
    Graphics Card #1Asus Rog Strix 1080ti 11GB
    MonitorSamsung syncmaster 2000
    Storage #1SSD NVME 1TB samsung
    Storage #212 TB HDD Segate
    CPU CoolerAsus Rog Ryo 240
    CaseCoolermaster C700m Cosmos
    Power SupplyAsus ROG Thor 850W
    Keyboard Asus ROG Claymore Core
    Mouse Asus ROG Pugio
    Headset Asus ROG DELTA RGB
    Mouse Pad ASUS ROG Balteuis QI
    OS WINDOWS 10
    Network RouterAsus ROG Rapture GT-AX11000
    Accessory #1 Lian LI RGB Strimmer pin cable
    Accessory #2 Lametric Subscriber Counter
    Accessory #3 Corsair ST100 Headphone Stand RGB
    Mar 2019
    18
    HI I think this will help
    http://www.xs-pc.com/fans-radiator-accessories/8-way-3pin-5v-addressable-rgb-splitter-hub-sata-powered-black
