Page 13 of 14 FirstFirst ... 3 11 12 13 14 LastLast
Results 121 to 130 of 136
  1. #121
    ROG Guru: Yellow Belt Array SK8 PC Specs
    SK8 PC Specs
    MotherboardMaximus XI Extreme
    ProcessorIntel I9 - 9900K
    Memory (part number)DDR4 G.Skill Trident Z RGB 4266Mhz 32GB F4-4266C17Q-32GTZR
    Graphics Card #1ROG Strix OC 2080Ti
    MonitorSamsung 49" CHG90 QLED Gaming Monitor 144Hrz 1ms
    Storage #1Samsung 850 Pro X-Three-1TB
    CPU CoolerHydro Series H150i Pro RGB 360mm Liquid CPU Cooler
    CaseCorsair Obsidian Series 1000D
    Power SupplyCorsair HX 1200i
    Keyboard Corsair K70
    Mouse Corsair Sabre
    Headset Sennheiser Game Zero Headset
    Mouse Pad Corsair MM800 RGB POLARIS
    Headset/Speakers Sennheiser GSX 1000 Audio Amplifier
    OS Win 10 Enterprise 64bit
    Accessory #1 Logitech G13 handpad
    SK8's Avatar
    Jan 2016
    143
    OK got a error 1hr 27min in. Do you want me to still set this next... Bump IO back to 1.25v and put SA to 1.27v
    Bios 602
    passed 8hr test on Karhu RamTest
    Set to Manual OC
    Dram Frequency 4266MHz
    Dram voltage 1.45v
    CPU VCCIO Voltage 1.25v
    CPU System Agent Voltage 1.29v
    Dram timing control 17-18-18-38
    Mode1
    Dram command rate set to 2N set dram current capability to 130%
  2. #122
    ROG Guru: Green Belt Array Phillyflyer's Avatar
    Mar 2012
    30
    539
    Quote Originally Posted by SK8 View Post
    Bump IO to 1.25 and SA 1.27
    Asus ROG Maximus XI EXTREME
    Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
    XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
    Swiftech Drive II / Swiftech MCP35X Pump
    Enermax Platimax 1200 Watt Power Supply
    32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
    MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
    (5)Samsung 840 Pro 128 GB In Raid 0
    (2) WD 1TB Black Edition
    Corsair 900 D
  3. #123
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    Quote Originally Posted by Phillyflyer View Post
    OK done and testing .....
    Set to Manual OC
    Dram voltage 1.45v
    CPU System Agent Voltage 1.27v
    Mode1
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  4. #124
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    Its still going at 1hr 41min scared to jinx it want this to pass lol 3252%
    with settings ...
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  5. #125
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    I jinxed it just failed :/ 1hr 45 min in
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  6. #126
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    Ok just seen this in pm ... Bump SA to 1.28v.....
    Set to Manual OC
    Dram voltage 1.45v
    CPU System Agent Voltage 1.28v
    Mode1
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  7. #127
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    Interesting read this if you have time its on Karhu ram test read page 4 last post he spells it out well..... I don't think RAM stability can be tested so singlehandedly. Sometimes errors occur fast sometimes they take a while to pop. I've used RAMTest a lot while testing coffee lake memories with two different motherboards / processors. What i have found with RAMTest is that usually 2000%+ is a solid starting point that hardly gives problems in daily use, but latest errors on RAMTest have ocured to me at ~5000% mark. After 5000% i have never got any errors. Anything below 2000% i wouldn't even call 'semi-stable'. Maybe they can pass some benchmarking, but nothing to write home about with stability.
    I usually test 24/7 for 10000% coverage just to see if i can find errors past 5000% smile.gif . Doesn't take longer than 2 - 3 hours. Depending on the speed of course.
    https://www.overclock.net/forum/1805...-ram-test.html
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  8. #128
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    And I just got a error at 57min 1835% ug lol
    with ...
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
    So this lasted longer 3252% before error 1hr 45 min error don't mind me trying to see your next move lol
    with settings ...
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  9. #129
    Mar 2012
    30
    539
    with ...
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
    Set the SA @ 1.29v
    Corsair 900 D
  10. #130
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    OK Boss doing it now :}...testing so we are looking for above 5000% to fully pass I take it my question is answered lol I think . I would say I need it to pass past 5000% as I play games like BFV fully a pc / cpu hog so my rig must be very stable :]
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
