Page 2 of 14 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 135
  1. #11
    ROG Enthusiast Array
    Jan 2017
    11
    43
    Yes, having a second PC or at least a tablet is essential
  2. #12
    ROG Guru: Yellow Belt Array SK8 PC Specs
    SK8 PC Specs
    MotherboardMaximus XI Extreme
    ProcessorIntel I9 - 9900K
    Memory (part number)DDR4 G.Skill Trident Z RGB 4266Mhz 32GB F4-4266C17Q-32GTZR
    Graphics Card #1ROG Strix OC 2080Ti
    MonitorSamsung 49" CHG90 QLED Gaming Monitor 144Hrz 1ms
    Storage #1Samsung 850 Pro X-Three-1TB
    CPU CoolerHydro Series H150i Pro RGB 360mm Liquid CPU Cooler
    CaseCorsair Obsidian Series 1000D
    Power SupplyCorsair HX 1200i
    Keyboard Corsair K70
    Mouse Corsair Sabre
    Headset Sennheiser Game Zero Headset
    Mouse Pad Corsair MM800 RGB POLARIS
    Headset/Speakers Sennheiser GSX 1000 Audio Amplifier
    OS Win 10 Enterprise 64bit
    Accessory #1 Logitech G13 handpad
    SK8's Avatar
    Jan 2016
    140
    I have 6 pcs I'm safe lol Two desk tops 4 laptops
    Bios 602
    passed 8hr test on Karhu RamTest
    Set to Manual OC
    Dram Frequency 4266MHz
    Dram voltage 1.45v
    CPU VCCIO Voltage 1.25v
    CPU System Agent Voltage 1.29v
    Dram timing control 17-18-18-38
    Mode1
    Dram command rate set to 2N set dram current capability to 130%
  3. #13
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    140
    I cant seem to get the ram stable on 4266 so this is what I did today ....
    This sec I have it on XMP2 and on 4000MHz
    Ram voltage is set to 1.45 v
    Dram voltage is set to 1.3 v
    CPU system Agent is set to 1.3 v
    In DRam timing control its on Maximus tweek 2
    ram timings set to 17,18,38 only gives 3 spots so I cant go 17,18,18,38
    Dram command rate set to AUTO
    This passed the Windows Memory Diagnostic tool so I will run memtest tonight as its a 7 hr or more test.
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  4. #14
    ROG Guru: Green Belt Array Phillyflyer's Avatar
    Mar 2012
    30
    536
    Quote Originally Posted by SK8 View Post
    The 3 spots your referring to actually gives you 17 -18- 18 -38 when imputed manually...If you run CPU-Z you will see that.
    Asus ROG Maximus XI EXTREME
    Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
    XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
    Swiftech Drive II / Swiftech MCP35X Pump
    Enermax Platimax 1200 Watt Power Supply
    32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
    MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
    (5)Samsung 840 Pro 128 GB In Raid 0
    (2) WD 1TB Black Edition
    Corsair 900 D
  5. #15
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    140
    I did see that when I got back on desktop but thanks just the same. Any idea if I should put it on 2T or keep it on Auto as this was the first time I got it stable at anything not default, sadly this is new to me :/ So please give advice if you can. Edit ...never have I had to do settings like this for ram so it fully has thrown me for a loop trying to get it going correct. I don't get why I cant pull off 4266 yet other then a setting is wrong still.
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  6. #16
    Mar 2012
    30
    536
    Try 2T or 2N
    Corsair 900 D
  7. #17
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    140
    OK will do thanks :] For now should I just stay on 4000MHz and let the 4266MHz go for just now as I cant seem to get it stable with the settings I did today anyway as it was the first thing I tried for lol. EDIT...
    This sec its all set at...
    XMP2 and on 4000MHz
    Edit if it passes memtest86 tonight then I will up the ram to the next one in the AM and see if it can pass the tests.
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  8. #18
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,832
    Use Karhu RamTest or HCI Memtest. Users should be pushing others away from stressing memory OC with Memtest86, as it's incapable of finding most instabilities on current platforms.
    https://www.karhusoftware.com/ramtest/
    https://hcidesign.com/memtest/
  9. #19
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    140
    Ok will look at both thanks and my bad as you told me this in the past sorry :] Any idea how I can get the ram up to 4266 ? It passed all I tossed at it yesterday on 4000 and this AM set it to 4133 and it seems to be passing this as well so far in the windows scans. As soon as I get it back to desktop I will put on one of the two tests you suggested.
    @Silent Scone I got this one as its not much $$ and seems like it will do more and more easy to work with.. https://www.karhusoftware.com/ramtest/
    Testing it now ya way more easy to work with Thank You :] 21 min into test. Truth be told I was sick to death of the 8hr tests lol
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  10. #20
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    140
    Well this was interesting tried to up the ram one more level up could not get into windows hit F5 in bios set it all back to default still could not get into windows no difference what I tried even clear cmos still no joy. I had to do a system restore point to get back into windows . Made it back into windows so now going to test this ram in default with Karhu RamTest if it fails then at least I know to RMA the ram as it has no xmp/ oc on it just now. If the ram fails my heart will sink but I am lucky as we do have another kit of this ram in the house for my husbands build and he still has a few parts to get yet.
    Edit ... If it passes the test with Karhu RamTest is anything wrong with the settings below at all ? I just do not get what I am doing wrong :/ Sadly I have not tested the ram yet with Karhu RamTest with the settings below yet so not sure it would pass either .
    Edit 2 ... If the ram passes then I will run sfc /scannow to be sure windows has zero issues still as well as I am not a fan of system restore at the best of times. I do know my windows had no issues yesterday so I have no idea why it would not boot into windows after I reset bios to default today as I checked all my bios settings more then a few times when this started .
    XMP2 and on 4000MHz
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
