Results 1 to 9 of 9
    ROG Member Array
    Jun 2015
    5
    Computer freeze and other issues
    Just recently built the following:
    ASUS Maximus XI Hero BIOS: 0805 set to all defaults
    INTEL I9-9900K No overclock
    G. Skill F4-3200C16-8GTZR (4 8GB modules)
    NZXT Kraken X62
    EVGA GTX 1080
    Computer freezes for a few seconds, then recovers after a few seconds. Sometimes the freeze will require a hard boot. System usually freezes when computer is idle. Computer wont freeze if playing a game, usually acts up when its not doing anything.
    One other strange issue is that Origin will not fully load and NVIDIA Geforce experience will not load completely. Some programs say I am not connected to the internet, but the computer is online and other programs are fine and interacting with the internet. Something is buggy about the LAN port.
    Things I have tried:
    Reloaded Windows 10 64Bit
    Reseated the CPU and NZXT AIO, ensured the AIO was not to tight (heard that overtight may cause weird CPU behavior)
    Installed Chipset v. 1828.12.0.1152
    Ive built numerous ASUS/INTEL boxes, but this problem is driving me batty... Ive read there may be an issue with running all 4 modules of G.Skill Tridentz RGB ram.
    Where to Start?
    Thanks....
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,455
    Quote Originally Posted by bruceanast@att.net View Post
    If that's not a single kit of RAM, then that mey well be the source of the problems
    If you have two kits...separate them by serial number and try one of them only...
    ROG Member Array
    Jun 2015
    5
    Quote Originally Posted by Arne Saknussemm View Post
    It was bought as one kit (4 modules)… I am going to uninstall 2 modules in DIMM A1 and B1 and see if there is a change.
    Apr 2012
    481
    13,455
    If it's one kit...then I'd test one stick at a time in the recommended slot...if they pass try a pair...then all four reseated...
    If that doesn't solve anything I'd do a clean install of Windows...minimal with no Geforce experience or AI suite or anything like that...
    Then look at the MB
    ROG Member Array
    Jun 2015
    5
    NZXT Kraken X62
    EVGA GTX 1080
    Where to Start?
    Thanks....
    Uninstalled ram modules in DIMM A1 and B1, no improvement. The program Origin loads, but the images/icons are missing and says Origin login is unavailable and says I am offline (which I am online and I can play games online). Computer still has intermittent hangs. DISCORD also will not start, it says its "starting" but never fully loads.
    I somehow think there is an issue with the lan port.
    I deleted the LAN driver, had the computer rediscover it and reinstalled v. V12.17.10.7
    I went into device manager and manually asked to update driver, it found and installed v. 12.18.8.4.
    After updating network driver, still having issues with freezing. Applications still have issues fully loading or recognizing that they are connected to internet.
    ROG Member Array
    Jun 2015
    5
    Ran Memtest86 thru 4 passes and no errors. I had two modules populated. I will try a fresh install of windows...
  7. #7
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,830
    1. Verify this happens at stock (UEFI defaults without XMP enabled)
    2. Test memory stabilty with https://www.karhusoftware.com/ramtest/
  8. #8
    ROG Member Array
    Jun 2015
    5
    My computer is now stable. The 64bit LAN driver posted on ASUS website is not the correct LAN driver for the Maximus XI Hero motherboard. I believe it is a 32 bit driver. Once downloaded, it wont execute or install. I went to the INTEL website and downloaded from their website. I had windows do an automated search, built that driver didn't work either.
    The way I diagnosed that it was a lan issue is I deleted the LAN from device manager and the system had absolutely no freezes. I left it on and tried several applications and it behaved normal. I was trying to install the drivers that came on the disk, but I have no disc drive, si I went to intels website and all seems to be good!
    Thanks for those that replied and lent their advice.
  9. #9
    ROG Member Array
    Mar 2019
    15
    I'm not sure, but i believe, youre right.... i have (had maybe) the same issue. Since 2 days (suspiciously long) i had no freeze. Could be so cool, if that was the issue. That problem killed me 3 weeks. I don't really think, that is a 32bit driver, but something must be wrong.
    Btw: Could be nice, if a asus employees read this..to check that lan driver file.
