Results 1 to 2 of 2
    ROG Guru: White Belt Array Asryan PC Specs
    Asryan PC Specs
    MotherboardAsus Maximus Hero X
    Processor8086k / 5GHz / delidded
    Memory (part number)32GB G.SKILL Trident Z RGB / 3466Mhz
    Graphics Card #1GTX 1080 TI EVGA FTW3
    MonitorASUS PG34Q - 34" GSYNC
    Storage #1SSD: Samsung EVO 850 - 250Go + Samsung EVO 850 - 500Go
    Storage #2HDD: WD Green 2To 64Mo 3.5"
    CPU CoolerCorsair H150i + ML 120 Pro
    CasePhanteks Enthoo Luxe tempered glass
    Power SupplyCorsair RMI 850 GOLD
    Keyboard Corsair k70 rapidfire
    Mouse Logitech G900 Chaos Spectrum
    Headset Logitech G933
    Headset/Speakers G560 Logitech
    OS Win 10 60 bits
    Oct 2016
    14
    123
    Any way to mix effects in asus AURA ?
    I tried everything but I can't find out how to mix effects on differents components in asus aura.
    let's say i want fixed colour on some fans plugued on an rgb Header but i want a breathing effect on the ram and on a led strip, is that possible somehow?
    Thanks !
    ROG Enthusiast Array
    Oct 2012
    48
    I don't think its possible. I wanted to have a different effect on my G.Skill ram but the only way from my understanding is to install G.Skills own software and not use Aura for that. The thing is I read that G.Skill software had problems and corrupted the memory so I staying away from that idea.
