Prime z370-a Realtek driver issue
psuhammer
Evening,
I have this motherboard running Windows 10 x64 (latest updates). I am using the Realtek onboard HD sound adapter with a rear and front panel connection to my case. Things have been working fine until recently when I updated to the latest driver and this (see attached photo) screen started popping up every so often (15 mins?). The screen will flash and sound cut out just before this pops up. Then, back to normal. How do I stop this?
I have a set of desktop speakers plugged into the green port on the back of the motherboard, by the way. I am not unplugging them.
79330
16 REPLIES 16
psuhammer
Just wanted to bump this as it is still an issue. Just hoping someone else has experienced this. I have tried everything. Drivers, firmware, latest BIOS, etc. It is as if randomly the sound cuts out and this prompt pops up. It's as if the driver uninstalls then reinstalls immediately.
I will try to look at event manager for the next instance to see if there is any correlation with events.
toronto699
Please Read These 2 threads , I have same issue Pop Up Device Connected" No Fix Yet I Am At The Point Of Buying Another Brand PC
https://rog.asus.com/forum/showthread.php?109477-Sound-New-device-connected
https://rog.asus.com/forum/showthread.php?109529
One consistent thing I have read is that Windows feature release 1809 wrecked havoc on audio devices. I do have that version installed. 1903 was just released so I am attempting to install that update and see if the issue is resolved. Will update this thread for others that may have this issue.
I have the same board with no audio issues with windows 10 but I don't load the realtek drivers. I use the built in windows 10 drivers. Try removing the Realtek drivers and let windows find the built in ones.
psuhammer
Thanks. With updated drivers, here is what I get now. It almost appears as if the driver unloads.
You can see the pop up that happens here:
80620
Once I click through the prompt, it reverts back to normal as shown here:
80621
Finally, here is the driver details:
80622
toronto699
cmos The Windows Driver Has The Same Issue Device Connected POP UP ,
Then you have a hardware issue.
toronto699
No Its Not A Hardware Issue , I Brought My Machine To An Asus Service Centre , They Say Not Hardware Issue , Read The Other Two Threads , Asus Service Center Said W 10 issue , Microsoft Support Said W10 issue
psuhammer
1903 did not fix the issue for me.
