Results 1 to 2 of 2
Thread: Subwoofer
    Bigwillt
    Guest
    Subwoofer
    I can't find any info on the subwoofers. How to tell if it's working? Does it have a seperate channel or controls, etc.? When I try to access setup in the control panel it just shows the left and right channel. Am I missing something or does it run on another channel in the background or something?
    Thanks,
    Tim
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    18
    1,334
    The subwoofer acts in conjunction with the stereo speakers, and has a crossover where the freqs below the xover point are filtered to the sub. This is all done internally. There are some limitations however, as playback from WASAPI, Kernel Streaming, or ASIO, being hardware streams, will bypass the xover filter and the sub will not put out any sound. (Which is why something like SRS Audio Sandbox failed to have good bass response)
    So no, you do not need to setup the audio for 2.1.
    Kicking Ass Since Today
