Results 1 to 10 of 10
    New ROGer Array
    Feb 2019
    4
    GL704GW underperforming with Destiny 2, plz help!
    So I used to own a gl702vm, which had 16gb of ram, a gtx 1060 6gb, and a i7-6700HQ processor. At the time of purchase, it was a pretty beefy laptop that had its issues with thermal throttling, but nonetheless, I updated the BIOS, made holes on the bottom cover for improved cooling and I was getting about 70-80 fps on Destiny 2 (1080p) on High settings. This year I decided to get a GL704GW that came with 16gb of ram (single channel), an i7-8750H, and rtx 2070 and a pretty sleek monitor with a 144hz display at 3ms. Looks really good on paper, but since I've started to use it, I've had nothing but problems. When I play Destiny 2 on it, I pretty much get the same performance that my old laptop gave me, which is around 60-80 fps on the highest settings (1080p). I'm thinking that with this new GPU, I should be getting a constant 120fps on it, but that's not the case. Even when I dropped the game from highest to lowest settings, the FPS doesnt move at all. I updated the bios to version to 303, updated all the drivers and I'm still getting that poor performance. Should I just return it and get something else? Is there something I'm missing in settings?
    ROG Member Array odavl123's Avatar
    Feb 2019
    13
    Hello!
    Im also owner of a GL704GW and this laptop dosent feel like top-end machine, even if it looks like it and costs like one xD.
    TBH on my ScarII even browsing windows feels kinda slow/shuterry. Games that i run should all run on 144fps, but they just dont, could be that bios/drivers/all other cr.a.p arent optimized, who knows?
    So no, you are not alone in this and i am taking my laptop back to the store and really think to change it, maybe even for a different mark.
    Best regards
    ROG Guru: Yellow Belt Array tap002 PC Specs
    tap002 PC Specs
    Laptop (Model)ROG Strix GL703GE-IS74
    MotherboardASUSTeK COMPUTER INC. GL703GE
    Processori7-8750H CPU @ 2.20GHz
    Memory (part number)16GB DDR4 2666MHz DRAM
    Graphics Card #1GTX 1050i
    Storage #1MICRON 1100_MTFDDAV256TBN
    tap002's Avatar
    May 2018
    13
    145
    ROG Guru: White Belt Array
    Jul 2018
    11
    120
    Quote Originally Posted by SaiST View Post
    1. Check if you enabled Overboost
    2. Check drivers
    3. Analyze logs from HWInfo, GPU-Z - or provide it here, so I can help you.
    Thank you
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    Have you monitored temperature? Try using hwbot and look at cpu temp (per core) and gpu temp. Just to rule anything out.
    ROG Enthusiast Array
    Feb 2019
    28
    26
    This is really strange tbh, I have the exact same model and easily get 120+ FPS on games like Overwatch, and 90+ FPS with games like BF5 when they're set to their highest settings.
    I have the GEForce Gaming experience that optimized those two games for me- maybe that's the difference? Other than that I haven't really messed with the graphics settings. In fact, I think I have my NVIDIA Card actually set to balanced mode instead of performance, which should make it even less powerful than it can be.
  7. #7
    New ROGer Array
    Feb 2019
    4
    Quote Originally Posted by KhuloodF View Post
    So it shuts down the same way even when I'm using my nvidia shield and geforce experience to remote play. I notice it doesnt happen when the laptop lid is open. I'm pretty sure its overheating because theres a few vents that become blocked when the lid is closed. I'm gonna try running in turbo mode and see if the high fan speeds help this problem.
  8. #8
    Oct 2012
    18
    71
    Your not getting the performance because the single channel memory is your bottleneck. I have the GL504GW and the moment I upgraded the memory to dual channel (32gb) I instanstly got 20 fps on majority of the games. Its like a night and day difference and I highly recommend to upgrade.
    Do some research and you will find significant differences in performance betwen single and dual channel
  9. #9
    New ROGer Array
    Feb 2019
    4
    Quote Originally Posted by mbushnaq00 View Post
    I already have it in Dual Channel mode, I bought another 16gigs. The problem is when I try to play games on an external monitor or if I use my Nvidia Shield to remote play, as im playing, the computer just shuts down or enters a sleep mode. I think it's because it's overheating, but im not 100% sure if the vents that are covered when u close the lid cause it to overheat.
  10. #10
    Feb 2019
    28
    26
    Hi- don't mean to steal your thread at all but I was wondering if you could tell me if upgrading with the additional 16 GB ram was worth the price? And what RAM stick did you use?
    Was the performance different significant (I play most games on ultra/high settings).
