03-07-2019 08:11 PM - last edited 3 weeks ago by ROGBot
03-07-2019 11:17 PM
03-08-2019 02:59 AM
Arne Saknussemm wrote:
That shows up in HWiNFO64?
HWMonitor is well known for reporting made up temps for sensors that don't exist....it's reporting 10 degrees for TMPIN6....you in the garden shed?
03-08-2019 03:01 AM
03-08-2019 03:09 AM
OK...so I reckon that's just a "false positive"...I'd stick with HWiNFO64 for now...:)
03-08-2019 04:15 AM
03-08-2019 09:10 AM
Silent Scone@ASUS wrote:
As above. If it bothers you, I'd contact HWInfo and ask them what they're referencing.
03-08-2019 09:12 AM
03-08-2019 09:22 AM
03-08-2019 09:28 AM
HWiNFO64 doesn't have it because it doesn't exist...so how can it be bad for the board? The reason I asked above is that HWiNFO64 is regularly updated with board profiles to avoid exactly this kind of thing. HWMonitor is always displaying temp in the hundreds of degrees...
The other software is also more bloatware than software....They all have 15 degrees and 9 degrees reported too....are you in an igloo? It's impossible for parts of your board to be below ambient temp...
It's worth noting that if you run more than one program that polls sensors they can often throw out garbage readings...
