Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    ROG Enthusiast Array Johnnie PC Specs
    Johnnie PC Specs
    MotherboardAsus ROG Rampage VI Extreme Omega
    ProcessorIntel® Core™ i9-9980XE
    Memory (part number)4 x G.Skill Trident Z RGB DDR4 4600 MHz 2x8GB (F4-4600C18D-16G)
    Graphics Card #1ROG Matrix GeForce RTX™ 2080 Ti
    MonitorAsus ROG PG27V
    Storage #1Samsung SSD 970 PRO NVMe M.2 PCIe 1TB
    Storage #2SanDisk Extreme II SSD 480GB
    CPU CoolerAsus ROG Ryujin 360
    Casebe quiet! Dark Base 700
    Power SupplyCorsair AX1500i
    Keyboard Asus ROG Horus GK2000 RGB Mechanical Gaming Keyboard
    Mouse Asus ROG Gladius II
    Mouse Pad Asus ROG Sheath
    Headset/Speakers Edifier S730
    OS Windows 10 Pro
    Network RouterAsus RT-AC66U B1
    Johnnie's Avatar
    Mar 2017
    46
    Overclocking advice for i9-9980XE + Asus ROG Rampage VI Extreme Omega
    Dear ROG Community,
    On 03.03.2018 i`m updated my PC
    CPU: Intel® Core™ i9-9980XE
    Motherboard: Asus ROG Rampage VI Extreme Omega
    GPU: Asus ROG Poseidon 1080Ti (Will be upgraded for Asus ROG Matrix 2080Ti Sli, when it will become available in Estonia)
    RAM: 4 x G.Skill Trident Z RGB DDR4 4600 MHz 2x8GB (F4-4600C18D-16G)
    Cooler: ROG Ryujin 360
    Storage: Samsung SSD 970 PRO NVMe M.2 PCIe 1TB
    PSU: Corsair AX1500i
    PC Case: be quiet! Dark Base 700
    My results are very poor with stock configuration:
    https://www.3dmark.com/spy/6460782 - Time Spy Extreme
    https://www.3dmark.com/spy/6460658 - Time Spy
    My PC purpose is only for gaming. I`m really need good advice from professionals, how to OC my rig for daily gaming. I don`t want to break records, but i want to get from my rig as much as it possible, but its need to be very stable and not over-stressed. Mates, please help me.
    For example 07.03.2019 i tried to use XMP profile. Even on 3500MHz for RAM, PC doens`t boot at all
    P.S If i made wrong new thread, i`m very sorry for that.
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,690
    No sorry needed...just more people will se a new thread...
    Can I ask about your RAM....is that a single kit....is says 4x and then the kit is 2x. Have you combined 2 of the same kits?
    Johnnie PC Specs
    OS Windows 10 Pro
    Johnnie's Avatar
    Mar 2017
    46
    Dear Arne,
    Unfortunately, in Estonia, its unavailable to buy 8 x kits, so yes, i bought 4 pcs of G.Skill Trident Z RGB DDR4 4600 MHz 2x8GB (F4-4600C18D-16G). Total i have 8 RAM sticks.
    I think it is very bad decision?
    Best regards,
    Johnnie
    Apr 2012
    505
    13,690
    Hmmm...OK I suspect a lot of problems come from that...
    Detailed explanation here https://rog.asus.com/forum/showthrea...atoes-overview
    Basically you want a single quad channel kit...and I know the maximum supported is 4000+ but that is difficult to achieve unless you stick to the kits on the QVL for the board.
    Even more difficult for all 8 slots.
    For gaming 64GB is not really needed...I know it's nice to fill slots for the "bling" but...
    Can you return the RAM?
    A single quad channel kit of 32GB at say 3600MHz would be way more stable and "plug and play"
    Johnnie PC Specs
    OS Windows 10 Pro
    Johnnie's Avatar
    Mar 2017
    46
    Dear Arne,
    OMG... I really didn`t know that.
    So best that i can get from G.Skill is:
    https://g-skill.co.uk/collections/de...00mhz-cl18-kit
    I only can try to return RAM
    Best regards,
    Johnnie
    Apr 2012
    505
    13,690
    OK, so that kit is qualified with the board and a single kit...the chances of it running ar much better...but it's still a lot of memory and a high frequency....you might need to spend time in the BIOS adjusting voltage etc. to get it running...
    Check out my happy build guide in my sig
    Maybe someone here has that kit and can comment...
  7. #7
    Johnnie PC Specs
    OS Windows 10 Pro
    Johnnie's Avatar
    Mar 2017
    46
    Dear Arne,
    I like high speeds and a lot of memory If be honest , only reason, that i bought system for Intel X-Series, because of 44 lane. I want to have RIG with SLI GPUs. And second reason, it gift from my birthday from my wife And about speed. The new Rampage VI Extreme Omega supports up to 4266 MHz, am i right?
    Your guide is priceless Really like it
    Best regards,
    Johnnie
  8. #8
    Apr 2012
    505
    13,690
    Yep...4266 is the max...but even then it depends a lot on the CPU...i.e. your particular sample and it's memory controller
    4266 might be possible for a smaller kit and after some playing in the BIOS.
    Cheers
  9. #9
    Johnnie PC Specs
    OS Windows 10 Pro
    Johnnie's Avatar
    Mar 2017
    46
    Hi Arne,
    Thank You very much for Your advice! It helps a lot to start understand the problem roots. So i really will try to return RAM, and try to buy Quad Channel kit. I hope It will works normally (https://g-skill.co.uk/collections/de...00mhz-cl18-kit).
    But i wait for CPU overclocking advice Something for maxed performance for gaming. Maybe 4.5 GHz for all 16 cores always? And there is thread, about Turbo boost 3.0 bug. Do i need to "Enter the UEFI and go to MFC Mode override, select Native OS Support" as Silent Scone adviced?
    Best regards,
    Johnnie
  10. #10
    Apr 2012
    505
    13,690
    Well, I don't have that platform...so hopefully some of the X299 crowd can help you out with things like that...but if Silent Scone advised that somewhere you can consider it good!
