Results 1 to 3 of 3
    ROG Junior Member Array
    Jun 2015
    1
    Rog claymore right arrow key problem !
    hi every one..
    i bought the claymore keyboard 7 months ago, I love my keyboard but there is a new problem..
    Right arrow key does not work in games or in Windows os
    RGB light modes change, when I press the fn key there is no problem
    but not working in game
    for example, in windows os ı write something...When I press it once, right arrow button it writes 4 times @ sign, then wipes it all off, writes 4 times q sign, then wipes everything, then writes different things randomly and then stops.
    fully automatic.. just press the right arrow key once...
    I formatted the computer
    delete and reinstall rog driver
    remove micro usb cable on keyboard, then ı I waited, then re-attached
    tried on different usb ports
    the result is always the same
    please help me
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,380
    I would contact tech support. Possibly ask for RMA if they don't have any suggestions. It sounds like it might be failing.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Administrator Array MasterC@ASUS's Avatar
    Aug 2014
    96
    1,492
    Try reverting the arrow key only or all the key assignments back to default (under Customize).
