Results 1 to 3 of 3
    New ROGer Array
    Aug 2018
    1
    FX502VM CPU temp problems with core.
    Hi everybody,
    So im having heating issues with my FX502VM. I know there are alot of threats about the GL502 (since its practicly the same) but i think this one has a different problem.
    I recently changed my backplate, bought a new one and did a cooling modification on that one. I added extra ventilation holes now directly above the fans. In theory this should be alot better. For the GPU it did. The temps almost never go above 70 degrees Celcius instead of 80/85 degrees that it was.
    Sadly with the CPU nothing really has changed with the temps. The package temp still goes up to 95/100 degrees Celcius. However i am noticing a rather big difference in the core temps. Core #0 and #2 both reached a maximum of 98 degrees Celcius while core #1 and #3 diddnt even went higher than 73 degrees Celcius. Images gives a clear view of the problem.
    The CPU temps were around 95 degrees Celcius before i did the cooling modification.
    .Click image for larger version.
    Now dust isnt a problem since i cleaned the pc like 2 days ago.
    This is really frustating since the I7 now constantly revs up, then sees the high temp, speed goes down again. This repeats itself constantly.
    Specs:
    ASUS FX502VM-FY250T
    Intel Core I7-7700HQ
    Nvidia 1060 3GB
    16GB Ram
    512GB SSD
    Thanks in advance.
    ROG Junior Member Array DymOK PC Specs
    DymOK PC Specs
    Laptop (Model)MSI GP62M 7REX
    MotherboardMS16J9
    ProcessorIntel Core i7-7700HQ @ 102.7MHz BCLK
    Memory (part number)Samsung M471A1K43CB1-CRC
    Graphics Card #1Nvidia GeForce GTX1050Ti
    Sound CardRealtek ALC898
    MonitorChi Mei N156HGE-EAL
    Storage #1Samsung 960EVO 250GB
    CPU CoolerAir (Stock)
    Power SupplyDelta Electronics 150W
    Keyboard SteelSeries Engine 3
    Mouse Defender Sky Dragon
    OS Windows 10
    Network RouterASUS RT-N12VP
    DymOK's Avatar
    May 2019
    1
    Check the pressure of heat sink to CPU. Also you can repaste it.
    New ROGer Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.305 )
    MotherboardAsus motherboard
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB
    Graphics Card #1intel Hd 620 graphics 1GB DDR3
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec 294
    MonitorLcd monitor
    Storage #1Samsung 850 Evo 250GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch. Toshiba 1TB 2.5 inch
    CPU CoolerBuilt-in
    Casefrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek with ice sound
    OS Windows 10 64bit 1809 build no 17763.503
    Network RouterBsnl Wi-Fi modem with router
    Feb 2018
    113
    Same Temps are there in different rooms and different locations .
    I think heat sink is spoiled or not working
