Results 1 to 3 of 3
    ROG Enthusiast Array sigtrm's Avatar
    Feb 2012
    47
    R4E: buzzing sound from speakers
    Speakers are constantly buzzing, or farting silently, funny thing is that whenever screen redraws buzzing sound is louder., eg. if I turn on some OpenGL demo it makes louder noises.
    I've set up with two KRK rokit6s (active speakers) connected via RCA to out(green) on MB.
    (KRK) (LCD) (KRK)
    I know these are unbalanced outputs but I didn't have this problem with the other PC. I've checked all connections and tried two different RCA->TRS cables. I've tried also connecting laptop, no issues.
    Also same GPU in the other PC and HD Audio plus KRK no problem.
    Another things I've checked: separating power supply cables to other outlets.
    PSU is no near MB, actuallly it sits atthe bottom of the chassis.
    I have also tried to disconnect OC Key.
    Setting up sound quality made buzzing a little quieter.
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 7980XE Custom IHS @ 4.6Ghz 1.23v
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1AORUS GeForce RTX™ 2080 Ti XTREME WATERFORCE WB 11G
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 512gb
    Storage #2Samsung 850 Evo 1TB x 2
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master Vanguard Series 1000W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    make sure you dont have any power cables near your speaker cables.
    Feb 2012
    47
    well these are totally separated, disconnecting DVI cables from graphics makes buzzing disappear.
    very strange, same GPU different PC no issues.
