Results 1 to 5 of 5
    ROG Member Array 877cms PC Specs
    877cms PC Specs
    MotherboardMaximus X Formula
    ProcessorIntel Core i7 8700K Coffee Lake
    Memory (part number)Corsair Vengeance RGB LED 16GB DDR4 3600 Memory Kit 2x 8GB SKU CMR16GX4M2C3600C18
    Graphics Card #1EVGA GeForce GTX 1080 SC Gaming 8GB GDDR5X with full waterblock
    Sound CardIntegrated
    MonitorBenq senseye3
    Storage #1250GB Samsung 960 Evo, 3D V-NAND, M.2 PCIe Gen 3.0 x4
    Storage #2512GB Samsung 960 Pro, M.2 PCIe NVMe
    CPU CoolerEKWB Supreme HF RGB waterblock
    CaseCoolermaster Cosmos S
    Power SupplyCorsair RM850i
    OS Windows 10 x64 PRO
    Network RouterASUS RT68U
    Accessory #1 Corsair Commander PRO, Digital Fan and RGB Lighting Controller
    Accessory #2 Case fans 120mm Corsair HD120 RGB LED
    Accessory #3 EKWB CPU & GPU
    877cms's Avatar
    Mar 2018
    12
    Arrow Replacing M.2 drive - couple of questions
    Hi all,
    My mobo is a Maximus X Formula.
    I will soon be replacing my M.2 drive (the one onboard with the heatshield cover and thermal pad).
    My questions are:
    1) Am I ok to re-use the thermal pad? The old M.2 is a 960 EVO 250GB, the new will be 960 PRO 512BG.
    I ask because the chips will have surely left dents in the thermal pad, so it won't contact as well?
    2) Best software to clone the old drive to the new one? (I can't be bothered to re-install Windows etc.. tbh)
    Thanks
    Maximus X Formula | 8700K | 16GB Corsair Vengance 3600 | EVGA GTX1080 SC | Watercooled CPU & GPU
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,542
    Thermal pads are pretty resilient. I've reused old pads many times with no ill effect. As long as you keep them clean and aren't stretching them way out they should be fine.
    I use Macrium Reflect. The free version works fine for migration. You have to pre-shrink partitions when moving to a smaller drive but since you are moving to a larger one it should be super easy. Just make sure one of your partitions is expanded to use the extra free space on the destination drive.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    49
    1,055
    xeromist has a good answer, but Just to offer you another option, I replaced mine and used new pads. THESE PADS are inexpensive and good quality pads and packaging. And you have two Samsung drives, so if you are replacing with a new Samsung drive you could choose the Samsung Data Migration software. I've used it twice very successfully.
    Davemon50
    877cms PC Specs
    877cms's Avatar
    Mar 2018
    12
    Thank you both, I will have a look at those replacement thermal pads.
    Since posting I did see the Samsung tool, it would seem the logical choice.
    However, I need to clone my D: drive (non bootable, just storage) and the software needs to run from Windows it seems.
    So I don't have enough M.2 slots for the total three drives.
    I guess I could buy a PCIe M.2 adapter but would prefer to avoid the cost, there must be a USB bootable tool.
    I'll have a look at Macrium Reflect, in the past I have used Acronis too..
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    301
    7,542
    In the past I've used Clonezilla, which is bootable. I've had issues trying to get it to clone a boot drive but since this is a data drive you should be fine.
Tags for this Thread
