How to adjust position and change colors of MSI/RivaTuner On Screen Display
Not_Enough_Rage
Level 11
I installed a clean update of MSI Afterburner and RTSS. I am having trouble remembering how to change the position of the on screen display. I want to position it on the monitor at the left side in the center. Right now it is on the left but I can not get it lowered to the center of monitor.
I want to change the colors of the text and numbers of the stats too. Can`t figure out how to get the number colors changed.
Also it will not let me enable frame rate on OSD. When I check mark for frame rate, it just goes gray.
5 REPLIES 5
Nate152
Hi Nate! How are you. Thanks for the video. It helped. I have the settings and colors the way I like them now. This stuff is easy to forget when you don`t use them for a while.
Nate152
Nate152
Yes, FPS and all the other stats that I wanted are showing. And I got the colors I wanted too. Your video showed me how to do it all. Thanks.
