Asus Apex Xi problems?
rubeen_9
Hi
I recently changed a formula x for an apex xi.
I do not understand how the overclock of this Mb works.
I have a 9900k at 5 ghz with water.
In formula x i have 5 ghz with 1.18 vcore. At 5.3ghz a need 1.32 vcore.
79413
Temp of package and cpu (peci) are on 73-86º.
However in apex xi need 1.12 vcore and i cant 5.3 ghz. Only can 5.2 at 1.25vcore.
With 1.3 vcore at 5 ghz. I have this. I have 20 º more than formula X . If I release 4 cibenech the pc turns off
79412
why? How I fix this?
7 REPLIES 7
rubeen_9
some can help me?
Silent_Scone
Super Moderator
Temperature disparity between the Formula XI is likely due to poor cooler mounting. Remove the CPU cooler and check for even mounting pressure.
Talking with a friend, I realized today that I have a lot of temp between the cores and it can be that.
hi again.
i remove the cpu cooler and I'm still having the same problem. I think the configuration is the problem. i have 0 avx, 1.15 vcore mode manual , llc8 (0 vdroop) , mode xtreme phases.
What can it be or what can I touch?
I think you try to compensate low vcore with high LLC, mine 9700K is working well with LLC6, just a slight droop, but I think 8 is a suicide, no wonder your temps are blowing up.
My guess is that llc works "better" on Apex and you don't need 8, like you did on Formula. Try 6 with vcore of like 1.3~ and see how the things are then.
have u got apex xi?
can u tell me your configuration. ?
i will try llc6.
thank you.
rubeen_9@ wrote:
have u got apex xi?
i will try llc6.
thank you.
I talk about it a bit here :
