Results 1 to 3 of 3
    ROG Junior Member Array
    Oct 2017
    2
    Maximus Hero VII Memory Issue
    I've started getting alerts about memory issues on my system, so I bought a set of 32gb memory DMMs to fix the problem and upgrade. Since I can't find any up-to-date lists of memory/mobo compatibility for the Maximus Hero VII, I got Corsair memory with the same specs as my old memory (240-pin, 1600mhz).
    The machine would not boot with the new memory at all. It'd start up, hum, but nothing. No beeps, either. Reinstalling the old memory got it to work.
    Now, this was the _second_ time this had happened: I tried upgrading my memory a year ago, but I figured I'd gotten a bad batch of Corsair memory. But twice? I'm wondering if there's a problem with my motherboard. Am I doing anything wrong?
    (And if I have to replace the motherboard-- well, would it be worth it to upgrade to a new mobo, CPU _and_ memory?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPCP&C Turbo Cool 1200w
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    308
    16,642
    Hi BrianSiano
    Welcome to the ROG forum !
    Power down your machine and install your corsair memory, hold the clear cmos button for 3 seconds then try booting.
    How does it go?
    Please list the complete specs of your pc and both kits of ram or post links to them.
    Oct 2017
    2
    It worked PERFECTLY! Now I can edit video with 32 gig of RAM! Again thank you!
    Quote Originally Posted by Nate152 View Post
    Hi BrianSiano
    How does it go?
Tags for this Thread
