Results 1 to 6 of 6
    ROG Member Array strat38 PC Specs
    strat38 PC Specs
    Laptop (Model)Dell G3 3779-7934BLK 17in
    MotherboardAsus ROG Maximus X Hero (WiFi AC)
    ProcessorIntel I7-8086K
    Memory (part number)2x16GB CMR32GX4M2C3000C15
    Graphics Card #1EVGA GTX 1080 Ti FTW3 iCX
    Sound Cardonboard
    MonitorAOC 352UCG 35in Curved 3440x1440
    Storage #1Samsung SSD 970 Pro 1TB NVMe
    Storage #2Micron 1100 2TB SSD
    CPU CoolerCorsair H100i Pro
    CaseCorsair 780T
    Power SupplyCorsair TX850M
    Keyboard Corsair K70 RGB MK.2 Cherry MX Red
    Mouse Logitech M705 Wireless
    Headset n/a
    Mouse Pad Amazon Basics
    Headset/Speakers Sony MDRV6 / Edifier R1208T 42W RMS
    OS Win10Pro x64 / Linux Mint v19 Cinammon
    strat38's Avatar
    Mar 2019
    6
    Setting Adaptive / Offset Voltage on i7-8086K on ASUS ROG Maximus X Hero (WiFi AC)
    Asus ROG Maximus X - i7-8086K 5.2GHz Adaptive Voltage Settings
    Adaptive Voltage:
    Attempting to Enable Adaptive Voltage to prolong CPU life by limiting damage due to Electromigration (high currents causing short or open-circuits) or Negative Bias Temperature Instability (NBTI) which is what causes transistors to degrade over time. They become more difficult to turn on, slower to respond and become more resistive to current as they age. NBTI is worsened by high temperatures and voltages which can be produced when overclocking.
    Adaptive voltage allows lower voltages and less current flow in CPU when not under load to minimize effects of electromigration and NBTI.
    Adaptive Voltage settings require SVID to be enabled in BIOS to allow Vcore and current draw to be lowered.
    UEFI "BIOS" v1901 Adaptive Voltage Settings:
    Extreme Tweaker
    - Overclocking Presets: (Ignore)
    - AI Overclock Tuner: Manual
    - BCLK Frequency: 100.000
    - Asus MultiCore Enhancement: Disabled
    - SVID Behavior: Best Case Scenario (Assuming good CPU cooling solution)
    - AVX Instruction Core Ratio Negative Offset: 2 (running AVX at max CPU speed of offset=0 may overstress CPU)
    - CPU Core Ratio: Sync All Cores
    1 - Core Ratio Limit: 52 (For 5.2GHz)
    - BCLK Frequency : DRAM Frequency Ratio: 100:100
    - DRAM Odd Ratio Mode: Enabled
    - DRAM Frequency: (User discretion depending on RAM being used)
    - XTreme Tweaking: Disabled
    - TPU: Keep Current Settings
    - CPU SVID Support - Enabled (For Adaptive Voltage Control, Disable for Manual Voltage)
    DRAM Timing Control: (At users discretion, did not modify these)
    External Digi+ Power Control
    - CPU Load-Line Calibration: Level 6
    - CPU Current Capability: 140%
    - CPU VRM Switching Frequency: Manual
    - Fixed CPU FVRM Switching Frequency(KHz): 400
    - CPU Power Duty Control: T.Probe
    - CPU Power Phase Control: Standard
    - CPU VRM Thermal Control: Auto
    - DRAM Current Capability: 130%
    - DRAM Switching Frequency: Auto
    Boot Voltages: Left all these on Auto
    Extreme Tweaker / Internal CPU Power Management
    - Intel(R) Speedstep(tm): Enabled
    - Turbo Mode: Enabled
    - Long Duration Package Power Limit: 4095
    - Package Power Time Window: 127
    - Short Duration Package Power Limit: 4095
    - IA AC Load Line: 0.01
    - IA DC Load Line: 0.01
    - TVB Voltage Optimizations: Auto
    Extreme Tweaker / Tweakers Paradise
    - Realtime Memory Timing: Disabled
    - FCLK Frequency for Early Power on: 1GHz
    (Remaining settings in this section left to Auto)
    Extreme Tweaker
    - CPU Core/Cache Current Limit: 255.75
    - Ring Down Bin: Auto
    - Min CPU Cache Ratio: 50
    - Max CPU Cache Ratio: 50
    - BCLK Aware Adaptive Voltage: Adaptive Mode (UEFI shows 1.296V at this point)
    - Offset Mode Sign: " - "
    - Additional Turbo Mode CPU Core Voltage: 1.300 (This is the actual Vc you wish to apply as a 'base' voltage)
    - Offset Voltage: 0.010 (This is the actual offset or additional voltage applied to the "Add.Turbo Mode CPU Core Voltage above)
    - Total Adaptive Mode CPU Core Voltage: 1.290V
    Note: For some reason, HWMonitor always shows much higher Vc than what is shown in the 3 settings above. See pictures below. Kept the settings shown above
    ( Settings in remaining section left on Auto. M/B displaying current voltages)
    DRAM REF Voltage Control: Did not change any of these
    Advanced
    - Hyperthreading: Enabled
    - Thermal Monitor: Enabled
    - Active Processor Cores: All
    - Intel Virtualization Technology: Enabled
    - Hardware Prefetcher: Enabled
    - Adjacent Cache Line Prefetch: Enabled
    - Boot performance Mode: Turbo Performance
    - SW Guard Extensions (SGX): Software Controlled
    - Tcc Offset Time Window: Auto
    Advanced \ CPU Configuration \ CPU Power Management Control
    - Intel SpeedStep: Enabled
    - CPU C-States: Enabled
    - Enhanced C-States Enabled
    - CPU C3 Report: Enabled
    - CPU C6 Report: Enabled
    - CPU C7 Report: CPU C7s
    - CPU C8 Report: Enabled
    - CPU C9 Report: Enabled
    - CPU C10 Report: Enabled
    - Package C-State Limit: C10
    - CFG Lock: Disabled
    - Intel Speed Shift Technology: Enabled
    Advanced \ Platform Misc Configuration
    - PCI Express native Power Management: Enabled
    - Native ASPM: Enabled
    - PCH DMI ASPM: Enabled
    - ASPM: L0sL1
    - DMI Link ASPM Control: L1
    - PEG ASPM: ASPM L0sL1
    - ASPM L0s: Both Root and Endpoint
    Advanced \ System Agent (SA) Configuration
    - VT-d: Enabled
    - DMI/OPI Configuration
    DMI: X4 Gen3
    - DMI Max Link Speed: Gen3 (Need to set to PCIe slot to Gen3 for max speed)
    Advanced \ System Agent (SA) Configuration \ PEG Port Configuration
    - PCIEX 16/X8_1
    - PCIEX16/X8_1 Link Speed: Gen3
    (Left remaining section settings below at default)
    Advanced \ PCH Configuration \ PCI Express Configuration
    - PCI Express Configuration
    - PCIe Speed: Gen3
    Advanced \ APM Configuration
    - ErP Ready: Enabled(S4+S5)
    Save Settings to Asus Overclocking Profile and name profile appropriately: Ex: AdaptVc5.2Ghz
    Save Changes and Reset
    In Windows: Run: powercfg.cpl
    - Select Power Saver Power Plan
    First screenshot is under 'no load' conditions with low Vc and low CPU speed.
    Second screenshot is under load conditions using IntelBurnTestv2. Note that the Vc=1.360V is higher than specified in UEFI settings. CPU is at 5.0Ghz because Intel Burn Test V2 was running an AVX test at the time so the AVX negative offset=2 lowered the CPU speed from 5.2 to 5.0GHz.
    Last edited by strat38; 05-16-2019 at 07:12 AM. Reason: Final Update after successful Adaptive Voltage Setup.
    ROG Guru: White Belt Array
    Apr 2012
    88
    Adaptive seems broken and provides way too much voltage at times. Spikes to 1.5v even while idle in BIOS. I'm staying clear of that.
    Offset works well for me and there is no extra voltage spike, even with AVX load.
    8700K / Noctua U12S / Maximus X Hero / 2x8GB Corsair Vengeance 3200MHz / EVGA GTX 1080 Ti / Seasonic Prime 650W / 4 x 1TB SSD / 970 Pro 512GB M.2 / Game Zero Headset / K95 Platinum / Logitech G502 / Win 10 x64/ ViewSonic XG2701 1080p 144Hz
    ROG Enthusiast Array joppiano PC Specs
    joppiano PC Specs
    MotherboardASUS ROG Strix Z390-F
    Processori7-9700K @ 5.0GHz
    Memory (part number)Corsair Vengeance RGB @ 3000MHz 16GB (2x8GB)
    Graphics Card #1ASUS ROG Strix 2070
    MonitorASUS ROG Strix XG258Q
    Storage #1Samsung 970 EVO Plus 500GB - M.2 Card
    Storage #2Toshiba P300 3.5´´ 2TB
    CPU CoolerNZXT Kraken X72
    CaseNZXT H700i Window Black
    Power SupplyCorsair RM750x
    Apr 2019
    29
    Quote Originally Posted by desolator4u View Post
    How does Offset mode works vs. Adaptive mode?
    When choosing Offset mode, you don't type in a specific voltage value, but rather a offset value of X.XXv, right?
    But what is the base voltage then?
    Apr 2012
    88
    Quote Originally Posted by joppiano View Post
    Apparently it has to do with VID, which are the voltages pre-programmed by Intel for the CPU and each of it's different frequencies/speeds.
    LLC and specified Offset values entered play a part in the final voltages as well. The drawback I see is any offset you enter affects all voltages from VID.
    In my case for example, I need 1.24v to run 4.8GHz on my 8700K
    With Offset enabled and set to +0.040, at load I get my 1.24v, as HWMonitor shows VID is 1.20v (1.20 + 0.4)
    That's with LLC 5. LLC 6 brings up the voltage to around 1.28v instead, throwing off the math...
    When i'm at idle with LLC 5, voltage is around 0.7v. It could be under that, but again, the +0.04v is also added to it.
    It doesn't seem like it's easy to be precise with voltages using this method, but again, my voltage adjusts according to speed and there is no extra voltage under AVX load (I've ran hours of Prime95 and RealBench to confirm). Both those benefits matter to me, so i prefer it over Manual.
    As you can see, i'm not very clear on it. I can only go off my experimentation. I've been googling for a while and there doesn't seem to be any guides really based on it. Sadly.
    strat38 PC Specs
    Sound Cardonboard
    CaseCorsair 780T
    Headset n/a
    strat38's Avatar
    Mar 2019
    6
    Using settings above, highest Vc is 1.36V. Machine goes into low power after a few minutes, fans and lights all turn off, (hibernation is disabled) wakes up from mouse, keyboard or power button with no issues.
    strat38 PC Specs
    Sound Cardonboard
    CaseCorsair 780T
    Headset n/a
    strat38's Avatar
    Mar 2019
    6
    To me, and I may be wrong, but the nomenclature used in the UEFI settings are not quite accurate. I've notated where these seem to be different in my view, which makes for an easier understanding of how to setup and use adaptive voltage settings.
Tags for this Thread
