Results 1 to 4 of 4
    ROG Enthusiast Array TheDragon PC Specs
    TheDragon PC Specs
    Laptop (Model)Asus G750jm
    Motherboardmsi z370-A-pro
    ProcessorIntel(R) Core(TM) i3-8350k
    Graphics Card #1Asus NVIDIA Dual-GTX 1060 6GB
    MonitorASUS ve278
    Storage #1M.2 NVMe Gen.3 x4 SSD
    Storage #2TOSHIBA 1TB
    CPU CoolerCooler Master Hyper TX3i
    Power SupplyCorsair Cx 550
    Keyboard Razer Cynosa Chroma
    Mouse Logitech G502
    Headset Logitech G933
    OS Windows 10
    May 2016
    37
    How to fix G750jm shutdown problem?
    Hello!
    I am a proud owner of an Asus G750jm (with Linux Ubuntu dual bootable, because Windows was behaving badly).
    Sadly my computer has started to shut down everytime I disconnect the charger, and when it is connected it stays on 1% all the time. Before anyone says something, no it is not Linux' fault as this was happening ages before I switched. Is there any possibility that I can fix this on my own or do I have to buy a replacement battery, if the latter where can I find one?
    Thanks for all the help!
    You are supposed to smear the cooling paste behind the CPU on the pins, right?
    ROG Guru: Green Belt Array
    Nov 2012
    59
    607
    Replace battery:
    ASUS P/N: 0B110-00200000 or 0B110-00200000M
    Amazon $40.
    TheDragon PC Specs
    MonitorASUS ve278
    Mouse Logitech G502
    OS Windows 10
    May 2016
    37
    Quote Originally Posted by jdfrench3 View Post
    How do I know which one and is it worth it to replace as it is getting quite old?
    Nov 2012
    59
    607
    Either model battery will work in your laptop.
    If you like your laptop, keep it. Otherwise buy a newer laptop. That is a question only you can answer!
