Results 1 to 10 of 10
    ROG Guru: Yellow Belt Array
    Jul 2013
    11
    130
    Gl504gw rtx 2070 power limit?
    is there any way to fix the power limit of this card? or this is normal.
    The card is running without issues, i was just wandering
    ROG Member Array
    Oct 2012
    18
    20
    I have the same issue.
    I guess this is how it is designed
    Jul 2013
    11
    130
    ok thanks i am not alone.
    I re pasted the laptop just to be sure but that is not related to power .
    Runs cooler tho
    ROG Enthusiast Array
    Feb 2019
    44
    Quote Originally Posted by TX2000 View Post
    i had the same problem with my GTX 1060 (6gb VRAM) and i undervolted it by adjusting the voltage/frequency curve in MSI afterburner. Since then no limiting issues neither voltage, power nor temp
    They are plenty of vids on youtube about the process. Its very easy though.
    Jul 2013
    11
    130
    thanks for the tip. i have being tinkering with msi afterburner and i almost have it
    Feb 2019
    44
    If you want to have more information i can recommand you this video. It helped me a lot and it was very easy to apply.
    https://www.youtube.com/watch?v=TpIkYr9aDc8&t=427s
  7. #7
    Jul 2013
    11
    130
    Found my voltage curve and is all resolved
  8. #8
    Jul 2013
    11
    130
    the results
  9. #9
    ROG Member Array
    Oct 2012
    18
    20
    the results
    Did you notice any difference in performance or temps?
  10. #10
    Jul 2013
    11
    130
    I say its about the same but i got lower temps because i re pasted and used liquid metal on the CPU and GPU
