Results 1 to 3 of 3
    ROG Member Array
    Aug 2015
    6
    Question Maximus XI 9700k OC with Power Savings
    Can someone point me to a guide that explains overclocking while maintaining the ability for voltage and speed to drop while not under load? Most of what I see online creates an overclock which is constant independent of load. Thank you!
    ROG Guru: Blue Belt Array jab383 PC Specs
    jab383 PC Specs
    Motherboard24/7 rig : Maximus VI Extreme
    Processori7 4790K
    Memory (part number)16GB Mushkin Redline 2400 10-12-12-28 + 16GB Corsair Vengeance 2400 10-12-12-31
    Graphics Card #1AMD Firepro W5000
    Sound CardM6E Supreme FX
    MonitorDell U2413
    Storage #1Kingston SH103S3240G SSD
    Storage #2Seagate ST1000DM003 1TB
    CPU CoolerCustom water loop, Delidded, Liquid Metal TIM
    CaseCoolerMaster HAF XM
    Power SupplyCorsair HX-750
    Keyboard Logitech G710+
    Mouse Logitech M705
    OS Windows 7 64 Pro
    jab383's Avatar
    Feb 2014
    107
    855
    The concept is 'adaptive' core voltage along with EIST or 'speedstep.' There are so many guides and discussions on setting adaptive voltage in BIOS around the forum, I'll not try to reproduce them. You can search the forum and/or google for those terms.
    ROG Member Array
    Aug 2015
    6
    Quote Originally Posted by jab383 View Post
    Thank you for the quick reply! is there one guide that you see as being definitive or particularly good to get started with? I'm not interested in getting every last Mhz out of the CPU, just looking for a good stable 24/7 overclock that preserves power saving features and doesn't push the cpu voltage too high.
