No equalizer settings using SPDIF on Crosshair VII Hero
jadotben
Hello,
Equalizer settings are not available in Sonic Studio when using SPDIF, it works fine when using jack.:confused:
I wonder why this would be turned off by default when using SPDIF since peoples using that are most likely to have high end speakers.:confused:
I'm of course dissapointed :mad: , I bought the most expensive AM4 motherboard, I have very good and expensive speakers and I can't adjust the sound.:(
Is there some kind of turn around ?:o
Thanks.
jadotben
Since nobody could help, here is a good way to get equalizer on your Crosshair Hero VII.
I removed the crappy Sonic Studio :mad: and installed Peace Equalizer.
First you have to install https://sourceforge.net/projects/equalizerapo/ and after this https://sourceforge.net/projects/peace-equalizer-apo-extension/ :cool:
This equalizer offers tons of settings and my SPDIF high end speakers never sounded so good. 😄
Retired
Not applicable
jadotben, I don't know why it's designed like that but I couldn't use the equalizer on Sonic Studio either while running S/PDIF. I guess the application is a simple program compatible for speakers mounted into the audio jacks.
