Results 1 to 4 of 4
03-21-2019 08:23 AM #1
- Join Date
- Feb 2016
- Reputation
- 10
- Posts
- 3
AiMesh (AC86U + AC68U) falls down to 2.4GHz and/or goes Offline
I have an AC86U working as a primary router, and one AC68U connected as an AiMesh node. Firmware 3.0.0.4.384_45149 on both.
Configured separate SSIDs for 2.4GHz and 5GHz. The routers use 5GHz band for communication and signal strength between the two is in range -62 dB and -59 dB, surrounding 5GHz channels are pretty much clear, so there should be no interference with others.
Problems:
- Ater a day or so, the connection between the two falls down to 2.4GHz and does not switch back to 5GHz until I reboot one of the routers.
- Ocasionally the node gets marked as Offline. The computers connected to the node loose connection to Internet, but I can still SSH to the router. Again, it has to be rebooted to get the connection back.
It annoys the hell out of me. Please, does anyone have a solution?
Thanks!
- Airtime Fairness: Disabled
- Multi-User MIMO: Enabled
- Explicit/802.11ac Beamforming: Enable
- Universal Beamforming: Disable
04-25-2019 12:26 PM #2
- Join Date
- Apr 2019
- Reputation
- 10
- Posts
- 1
I have had the same problem for about two years now. I have a 86U as my router and have tried THREE different 68U as nodes. ALL of them will go offline without about 72 hours. Sometimes they go offline within 24, 48 hours...totally random. If I reset my router and nodes, they will go back online but then repeat the same offline behavior.
Every time new firmware comes out, I am excited to try it, but alas, it fails every time. I have reached out to ASUS tech support and they were completely useless, basically telling me there is no problem on their end. I am exasperated and basically gave up about a year ago.
11-01-2019 02:47 AM #3
MyDNA PC Specs Motherboard ASUS ROG Maximus XI Extreme Processor Intel i9 9900K Memory (part number) CMK8GX4M2B3200C16 Graphics Card #1 ASUS STRIX Gaming GTX1080ti 11GB Monitor AOC AGON AG271QG Storage #1 Samsung 970 Pro NVMe M.2 SSD 1TB CPU Cooler Thermaltake Floe Riing 360 Premium AIO Case Fractal Design Define R6 Black Power Supply Corsair AX1600i Keyboard Razer BlackWidow Chroma V2 Mouse Razer Naga Chroma Headset/Speakers Editier M1370BT OS Windows 10 Pro x64
- Join Date
- Jan 2016
- Reputation
- 10
- Posts
- 7
not sure if your router is a DSL-AC68U, if it is there's a firmware update Version 3.0.0.4.384_81140 that might fix your issue:
Webpage:
https://www.asus.com/Networking/DSLA...Desk_Download/
Direct download:
https://dlcdnets.asus.com/pub/ASUS/w...0438481140.zip
MD5 of unzipped firmware file: 33fa13b545b5c8eff24c4fdb421462e0
06-24-2020 08:21 AM #4
- Join Date
- Jun 2020
- Reputation
- 10
- Posts
- 1
Is this problem really fixed? I am on firmware 3.0.0.4.384_81930 with a newly bought AC86U router as node. Device connected to the node often reports wifi connection drop. And every few days the node will go offline. I am very disappointed. Just as I typed, wifi connection drops.. Bravo.
