Results 1 to 2 of 2
    ROG Guru: Yellow Belt Array Sverre PC Specs
    Sverre PC Specs
    MotherboardAsus Maximus X Formula
    ProcessorIntel Core i7-8700K
    Memory (part number)CMD16GX4M4B3200C15
    Graphics Card #1ROG Poseidon GeForce® GTX 1080 Ti
    Graphics Card #2ROG Poseidon GeForce® GTX 1080 Ti
    Monitor1 x Asus 27" LED FreeSync MG278Q + 2 x Benq XL2420T
    Storage #1C-drive: Samsung 960 EVO 250GB M.2 PCIe SSD
    Storage #2D-drive: Force Series LS 480GB
    CPU CoolerEK-Supremacy MX
    CaseCooler Master Cosmos C700P
    Power SupplyCorsair AX1500i
    Keyboard Corsair Gaming K95 RGB PLATINUM
    Mouse Corsair Gaming M65 Pro RGB FSP
    Headset Logitech G930
    Mouse Pad Built into the computer table
    Headset/Speakers Logitech z906
    OS Windows 10 pro 64-bit
    Network RouterZyxel P8702N
    Accessory #1 Several HDD’s 1, 2 and 3 TB
    Accessory #2 Aquaero 6xt + a lot of water cooling stuff.
    Accessory #3 UPS BlueWalker PW UPS VI 2200 SH
    Apr 2012
    141
    How does the Poseidon GTX 1080ti water block work?
    Is the water just streaming through a tube or is there some sort of similar system to the CPU blocks, with micro fins or whatever they are called? I probably have high restriction on my water flow, but there is, as far as I can understand, only one place to look, the CPU block, unless there's something special with the water block on the Poseidon.
    I have 2 Aquastream Ultima pumps in series, a block on the Aquaero 6 XT (which is basically totally open), the MosFet block on the Maximus X Formula, an Aquacomputer Vision CPU block, 2 Poseidon GTX 1080 ti, and a Mo-Ra3 radiator. Total water loop length is about 3 meters. At normal pump speed (3550 rpm, because that's what gives the lowest noise level) I have around 20 l/h (hard to say because the flow meter only measures accurately down to 30 l/h) and at 5000 rpm it increases to around 50 l/h. This, in my experience is way too low, so I'm guessing on the CPU block being clogged, but I have no idea how the Poseidon water block functions, and if there could be any clogging there.
    [/URL]
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,465
    It's much harder for clogging than conventional waterblocks.
    But it's not full cover block. Good thing is because Phanteks, Bitspower and EK blocks for ASUS Strix are compatible.
    I want to enjoy in natural look of ASUS GTX1080Ti Poseidon until full cover block price drop to 70-80 euro.
    Than I will switch on full cover, more to change look and to stay for some time.
    Graphic cards manufacturers no reason to change so fast PCB layout of graphic cards when new series show up.
    They could stay with similar layout and than same waterblock could be used on 2-3 generation.
    I remember EK 780 Classy waterblock is compatible with
    780 Classified
    780Ti Classified
    980 Classified
    980Ti Classified
    1080 Classified
    ... same EK CPU Block, full cover. That's amazing if all brands do that, special for cards like Strix.
Tags for this Thread
