Results 1 to 7 of 7
    New ROGer Array
    Mar 2019
    4
    how to switch off rtx 2060 strix power leds?
    my thread got removed dont know why?
    im trying again.
    how can i switch off rtx 2060 strix power leds? its disturbing my sleep.
    ROG Guru: Orange Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD Samsung 960 EVO 256GB
    Storage #2SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit 1903/19H1/18362.x
    MoKiChU's Avatar
    Aug 2013
    101
    338
    Quote Originally Posted by vistascape View Post
    im trying again.
    You can't.
    ROG Member Array
    Mar 2019
    6
    Quote Originally Posted by MoKiChU View Post
    You can't.
    This. But you can use something like this or this to hide it.
    Regards
    New ROGer Array
    Mar 2019
    4
    thank u.
    r u sure that liquid tape wont harm my gpu?
    very bad from rog's side that they didnt make it possible to switch of those damn lights.
    ROG Member Array
    Mar 2019
    5
    im trying again.
    are you talking about the strix RGB leds or the GPU's power on led (the green one)
    if you are talking about rgb leds you can simply turn it off from asus strix software but if you say about the power led you cant you only can switch off your psu from behind when you close your pc while you're not using it and turn it on again but i dont reccomend that cuz it may harm your PSU in long time you can cover your case with black sheet or something like that dont tape your gpu the tape may melt in time while working .
    ROG Member Array
    Mar 2019
    6
    thank u.
    Hey.
    You should only use electrical tape.
    Usually, you can find the voltage information with which you should use it on the tape.
    For example this one can be used up to 6000V (high voltage), which should be totally okay and not harm your GPU.
    Edit. PS:
    I also used the one above and its totally fine. Im not really a fan of the liquid, because this change will be permanent, but you can also use it. Just take a look at the max voltage of the tape before using it.
    Best regards
  7. #7
    New ROGer Array
    Mar 2019
    4
    i used this one:
    Made of soft, elastic PVC. Good all-round tape for insulation, winding, splicing, bundling etc. Thickness: 0.18 mm.
    Tensile strength: 22 N / cm
    Extensibility: 200%
    Steel adhesion: 1.5 N / cm
    Impact strength: 6 kV
    Temperature resistance: -15 ° C to +50 ° C
    Complies with EN 60454-3-12: 2006
