Results 1 to 9 of 9
    ROG Member Array
    Jan 2019
    22
    Help! PC not showing anything on monitor after z390-i bios update and profile load
    Steps:
    1.) I loaded the latest bios update onto a usb
    "Version 2203
    2019/03/227.97 MBytes
    ROG STRIX Z390-I GAMING BIOS 2203
    Updated uCode for the latest Intel processor
    Supported JEDEC standard DDR4 32GB memory"
    2.) The pc restarted, and I went to instant flash to update bios, which said it was successful
    3.) The computer restarted, so I took out the usb
    4.) Before windows fully loaded, I got into bios again and saw that everything was set to stock, so I loaded my regular 5.1 Ghz profile and hit f10
    5.) The computer restarted and stopped showing anything on the screen.
    I restarted, and it didn't work. I unplugged and plugged the computer, and it still didn't get any image on the screen.
    Please help. What should I do?
    I'm thinking I have to clear cmos now, but I think the cmos battery is enclosed on the z390-i, so I might have to clear rtc ram. The manual said short the two pins to clear rtc ram, but with what? I didn't find a jumper cap in the mobo box. I looked around and found another asus manual that said I could short the two pins with a screwdriver.Would using a screwdriver on those two pins work?
    ROG Guru: Yellow Belt Array SK8 PC Specs
    SK8 PC Specs
    MotherboardMaximus XI Extreme
    ProcessorIntel I9 - 9900K
    Memory (part number)DDR4 G.Skill Trident Z RGB 4266Mhz 32GB F4-4266C17Q-32GTZR
    Graphics Card #1ROG Strix OC 2080Ti
    MonitorSamsung 49" CHG90 QLED Gaming Monitor 144Hrz 1ms
    Storage #1Samsung 850 Pro X-Three-1TB
    CPU CoolerHydro Series H150i Pro RGB 360mm Liquid CPU Cooler
    CaseCorsair Obsidian Series 1000D
    Power SupplyCorsair HX 1200i
    Keyboard Corsair K70
    Mouse Corsair Sabre
    Headset Sennheiser Game Zero Headset
    Mouse Pad Corsair MM800 RGB POLARIS
    Headset/Speakers Sennheiser GSX 1000 Audio Amplifier
    OS Win 10 Enterprise 64bit
    Accessory #1 Logitech G13 handpad
    SK8's Avatar
    Jan 2016
    143
    Not sure if this will help you or not but with my Maximus XI Extreme MB and bios update I have to use a HDMI cable on my screen until I can get into bios and set up the boot area correct again to use my DP cable.
    Bios 602
    passed 8hr test on Karhu RamTest
    Set to Manual OC
    Dram Frequency 4266MHz
    Dram voltage 1.45v
    CPU VCCIO Voltage 1.25v
    CPU System Agent Voltage 1.29v
    Dram timing control 17-18-18-38
    Mode1
    Dram command rate set to 2N set dram current capability to 130%
    ROG Member Array
    Jan 2019
    22
    I've done this before, but this time it didn't work for this problem. Thank you though.
    ROG Member Array
    Jan 2019
    22
    I used a flathead screwdriver on the two pins, and Windows finally loaded. I attempted to load my OC profiles, but everyone of them just resulted in an endless boot with no image showing up on the screen, so I'm guessing the problem has to do with the latest z390-i bios update, which is version 2203. For now, version 2203, which was released 3/22/2019, is a hard avoid.
    ROG Guru: White Belt Array
    Nov 2015
    124
    Quote Originally Posted by SK8 View Post
    what bios are you using?
    have you tried using the nvidia firmware update to see if it fixes it?
    i've heard it fixes it for some while doing nothing for others.
    are u plugging in the dp cable in the very left port?
    there is a priority which is dp1 and dp2, same with hdmi1 and hdmi2
    ROG Member Array
    Jan 2019
    22
    Quote Originally Posted by SirWaWa View Post
    I'm using the latest Nvidia game-ready driver, which is version 419.35. I used a separate monitor with HDMI when I had problems getting it to load windows. so I know it's not a connection issue. I reverted back to Bios version 2012, and I'm not having any problems.
    The latest bios, which is version 2203, has been problematic for my setup. I mean I could get into Windows by setting everything to default, but when overclocking, it just ends up in an endless cold boot loop.
    Asus please fix this.
  7. #7
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    Quote Originally Posted by tml4191 View Post
    He is talking on firmware update for the video card it only helps some not all .... https://www.nvidia.com/object/nv-uefi-update-x64.html
    I feel your pain as this this is my first ROG MB to give me the same crap with the screen never seen it before . Small trick I used when it acted up on bios 805 was just unplug the screen for a second and plug it back in and could see windows again. The crazy part is I had this video card in my Rampage Extreme V build it never did any of this crap. I got so fed up with bios 805 I got rid of it and put in bios 602 as I would sooner have a old stable bios then a bios to make more issues then it is worth. For me bios 805 mucked up the ram OC as well as my sound on desktop for my Sennheiser amplifier and headphones and made my screen act up. As soon as I put her on bios 602 my sound was fixed my OC took and no screen issues so far. So needless to say I am in no rush to try the new Bios to come out a few days ago for my MB lol. I will hold off for now until I see how people say on it.
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
  8. #8
    Nov 2015
    124
    I have the same mobo as you and i'm running 0602. I'm using dual monitors via hdmi and I get random black screens for 1-2 secs then it comes back on, only on monitor 1. Anyways, I am wanting to get new monitors 144hz, freesync and use dp. This doesn't bode well if you're having problems and it's dp and mobo related. I have no problems seeing the bios or windows with hdmi though. BTW on the original bios (before 0602) I could not see the splash screen before windows on hdmi, DVI worked fine when I used a converter. When I upgraded to 0602 it was fixed. Have you tried 0903?
    Anyone out there using MEXI with dp monitors with no problems? See bios and everything? Does the type of video card even matter?
  9. #9
    SK8 PC Specs
    Mouse Corsair Sabre
    SK8's Avatar
    Jan 2016
    143
    No so scared to have this all mucked up again lol so have not gone near bios 903 yet. The guy on this site who helped me OC my ram is testing 903 if he gives the green light I will try it. But I am in no rush to head into another war with this MB lol. My rig and screen are so big not easy to move so I have a HDMI cable always hooked up to the screen since this build was done. I just keep the HDMI near by NOT plugged into video card just near by until its needed as every bios update I have to use HDMI since we did this build. In truth it makes me nuts but it is what it is :/
    I ran 3 screens since the gtx690 card still use 3 screens on spare rig but I got fed up with bezel with gaming and went to this Samsung 49in curved 144hrz 1 ms refresh I love it . Why less bs to hook up one screen then 3 screens :} Every video card driver set the 3 screens up again meh after almost mmm about 10 years I got tired of it / My advice is look at one large screen less hassle in the long run . If you want I can post a pic of it .
    Bios 602
    Set to Manual OC
    Dram voltage 1.45v
    Mode1
Tags for this Thread
