Results 1 to 3 of 3
    ROG Guru: White Belt Array
    Jan 2013
    12
    91
    Question on Build of ROG RAMPAGE VI EXTREME OMEGA
    Hi Guys,
    I'm in the process of buying all parts required for the new build.
    I was wondering if I can complete a build now and in a few months can come back and install 2 M.2 Drives to the motherboard behind the fancy Asus cooling panel, between PCIE sockets.
    With a MSI RTX 2080TI EK graphics card installed can you still remove the panel and add more M.2 drives?
    Thanks
    MB: ASUS Rampage V Extreme
    CPU: Intel Core i7 5960X Extreme Edition
    RAM: Dominator® Platinum Series 32GB (4 x 8GB) DDR4 DRAM 2800MHz
    PSU: Corsair AX1200i Digital ATX Modular
    GFX: 3 x EVGA GTX Titan Black Superclocked 6GB
    SSD: 2 x Samsung 850 Pro Series 512Gb SSD Raid 0
    HDD: 2 x WD4003FZEX WD Black 4TB Raid 0
    1234;
    2 x WD1000DHTZ WD VelociRaptor 1TB Raid 0
    MON: Dell Ultra Sharp 32 Ultra HD Monitor - UP3214Q
    CASE: Silverstone Temjin TJ11 Black with Window Case
    OS: Win7 x64bit
    ROG Guru: Orange Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    473
    Hi Counteragent,*
    On the R6e you have to release the pcie lock ( allowing the card to come forward slightly) then you can slide the over out,
    I believe the Omega is the same situation but I’m sure someone more in the know will confirm that.
    It is easier if you take the gpu out though.*
    ROG Junior Member Array JJ@ASUS's Avatar
    Nov 2017
    1
    You need to remove the entire cover plate. Which is affixed via 4 screws. If you have a graphics card it will need to be removed before you can do this as the heatsink is part of the entire plate ( heatsink ). This is different than some other boards where we have an individual heatsink. For ease of use I would use the DIMM.2 ( dual M.2 ) slots which are on the board. They get direct intake airflow and are easier to mount / install.
