Results 1 to 7 of 7
    New ROGer Array iquit040 PC Specs
    iquit040 PC Specs
    MotherboardX399 Xenith Extreme
    ProcessorAMD 2990WX
    Memory (part number)64gb DDR4 3000
    Graphics Card #1PNY GTX 1080 ti
    Graphics Card #2PNY GTX 1080 ti
    Graphics Card #3PNY GTX 1080 ti
    Graphics Card #4PNY GTX 1080 ti
    MonitorAW3418DW
    Storage #1Samsung 960 Pro 1tb nvme
    Storage #2Intel 2tb nvme
    CPU CoolerEK monoblock
    CaseTower 900
    Power Supply2x EVGA 1200w platinum
    iquit040's Avatar
    Mar 2019
    5
    Arrow Zenith Extreme - SLI issues using slots 1/3 per manual / bios suggestion
    I have an issue with performance when running SLI in the asus suggestion configuration (slots 1 and 3). Games will have random stutters and sometimes crash the game, and other times completely lock the system up. When i disable SLI completely, the issue goes away. I looked up the Die access to the different PCI slots, slot 1 and slot 3 are on different Die’s and I am assuming this is the cause of the problem. My original build was a 1950x and 2x 1080ti and the issues were occurring then as well. Since then I have swapped out the Zenith Extreme motherboard for a new one, changed out the processor to the 2990wx, memory 8 new modules, and installed 4 new 1080ti different mfg / model. I am noticing though when SLI is using the suggested slots though, Same problem. I am wondering if anyone else has ran into SLI issues on the Zenith Extreme (besides the 2x 2080ti issue i had seen).
    For the record: slot 1 and 2 SLI actually runs perfectly and scales appropriately. Has anyone else seen any issues SLI across the dies using slots 1 and 3?
    (in the situations I am talking about I have disabled the other cards using the switches on the motherboard so I am only using 2 cards not all 4, and I tried using different SLI bridges as well)
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    Hey Iquit040
    Actually I gave up on SLI just before I bought this platform, so I never ran it on the Zenith Extreme...
    Are you on the latest BIOS? Have you tried changing RAM Distributed/Local mode (not sure if that would help just an idea)
    Have you got the EZ plug populated (molex bottom of board)
    You sure it's GPU related not RAM? I kind of guess so if SLI works on 1/2 but not 1/3
    iquit040 PC Specs
    ProcessorAMD 2990WX
    MonitorAW3418DW
    CaseTower 900
    iquit040's Avatar
    Mar 2019
    5
    Quote Originally Posted by Arne Saknussemm View Post
    Hey Iquit040
    First off thanks for responding to my post.
    This might be my last SLI rodeo with all the fun I have had with this build. I am on the latest bios, have tried different memory and gpus at this point. When I had the 1950x still, I did try local mode, didn't help. I do have the EZ plug populated as well. I am really thinking at this point it has to be either be a Zenith Extreme board issue or X399 cross die communication issue. I was hoping that someone else would speak up and say they have seen it too, but I haven't found anyone else complaining about this issue.
    Things that have changed at this point:
    Processor: 1950x to 2990wx
    Motherboard: Swapped to a different Zenith Extreme (back when I had the 1950x) and no change, so swapped back
    Memory: Have tried 4 - 8 slots populated and with 2 different sets / MFGs
    GPUS: Originally had 2x gigabyte gaming oc 1080ti, now have 4x pny 1080ti on liquid (issue still exists), I have disabled 2 cards every time I am testing a different configuration to avoid that adding to the mix.
    Adding a Picture of the monster build below so the setup makes a little more sense.
    ROG Guru: Yellow Belt Array Cory29 PC Specs
    Cory29 PC Specs
    MotherboardROG Zenith extreme x399
    Processor1950x
    Memory (part number)G Skill F4-3200C16-8GTZ - 64gb
    Graphics Card #1GIGABYTE GeForce GTX 980 Ti WF
    Monitorcintiq 22hd touch
    Storage #1Sam SSD 850 EVO 1TB
    CPU Coolerxspc block - D5 - 3x120 slim rad
    CaseView 71 (doesn't fit board)
    Power SupplyEVGA supernova 1000G3
    Keyboard K95
    Aug 2017
    131
    Personally I could get very few games to run in 4 way sli - and have less issues with 2 way but still run into stuttering and crashing too ...
    this is on both amd and intel platforms support kind of fell out with developers when nvidia limited sli to only 2 cards
    I can render on all 4 like a beast though (daily I only have 1 card in my system because of the random issues)
    not saying there isn't a problem but you have to do allot of research and testing to figure out if its the board or the game or the cards
    iquit040 PC Specs
    ProcessorAMD 2990WX
    MonitorAW3418DW
    CaseTower 900
    iquit040's Avatar
    Mar 2019
    5
    Quote Originally Posted by Cory29 View Post
    Yeah it takes the perfect setup and all kinds of tweaks to get 4 way sli working. I just find it odd that everyone suggests 1/3 2 way sli causes all kinds of problems for me, but 1/2 and 3/4 doesn't. No one else has documented it. I dug through some youtube videos on builds/ benchmarks and saw some similar "terrible" fps counts and people didn't complain or mention issues. I am guessing no one has noticed it, or bothered trying 1/2 config due to not having the 0 slot sli bridges. I just wish AMD or mobo mfgs would say, yes we have identified this issue, and stop suggesting 1/3 slot usage. I have had headaches for over a year trying to solve it and just trying it in the different slot config stopped it. If that issue could be solved, then I would start trying to get 4 way sli to work (doubt that will ever happen)
    AS185
    Guest
    I have 2 Geforce 1080Ti's in SLI running on this platform just fine. I had some micro-stuttering when playing DOOM recently, but that's because I updated my Nvidia drivers. I'm assuming this could be an issue with your drivers, iquit040.
    With the recent BIOS update to 1601, for a while I didn't know that the platform can actually overclock the random access memory speed without interfering the base clock. So I thought that my crashes where caused on DOOM to that however I checked my other games and everything just worked fine Try establishing the minimum driver setting's on Nvidia control panel. It might take you an hour or more to find the best setting's on Quad-SLI.
  7. #7
    iquit040 PC Specs
    ProcessorAMD 2990WX
    MonitorAW3418DW
    CaseTower 900
    iquit040's Avatar
    Mar 2019
    5
    gave up on quad sli
    I have since moved to dual Titan RTX setup. Issues have since gone away. Dunno why the 1080ti's had the problems but I just couldn't keep dealing with the issues.
