Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    Jul 2017
    Question Zenith Extreme - No boot !
    I just put my new motherboard. But I have trouble when i start.
    My question is: What is the minimum connectivity to achieve to observe a sign of life of the motherboard? Is the 24 and 2x8 pin + only the cpu pressing the "START" on the motherboard to observe a light or the OLED screen?
    I only have the RGB of the card and the buttons "start" and "reset" light. And nothing changes when pressing "START".
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    To boot the pc you need all power connections...ram...gpu...cpu(cooled)...monitor will help see what's happening...
    The minimum sign of life is connecting psu to board and seeing lights...start button etc. But that wont boot...of course
    ROG Member Array
    Jul 2017
    Quote Originally Posted by Arne Saknussemm View Post
    The pc don't boot with all connections. So i try to find the trouble with the minimum of connecting.
    I think that if i have only CPU (no RAM, no gpu, etc...) when i press "start" on the motherboard i will have at least the Q-led, the OLED with an error code, and a fan that turns no ?
    ROG Member Array
    Jul 2017
    The motherboard went to an ASUS repair center.
    ROG Member Array
    Jul 2017
    The mobo came back from the repair center...and i have the same trouble !!!!! The have changed 2 Resistence (RES 10K Ohm 1/16W and RES 0 Ohm 1/16W.
    I'm tired...3 weeks that not turn
    My question is : what should the mobo do when we connect only the 24pin and the 2x8 pin on the psu and just that and we press on "start" please ?
    ROG Member Array
    Jul 2017
    Psu tested OK on an other PC
  7. #7
    ROG Member Array
    Jul 2017
    is anyone can tell me if the mobo with only the psu plugged must do something when i press "start" ? erreur code on the oled etc .. ?
  8. #8
    ROG Member Array
    Jul 2017
    After two return trips to the repair center and an exchange with an refurbished card ... it still does not work! But this time a little better the card tests the CPU at power up. But nothing else after the start. I am damned !
  9. #9
    AS185
    Guest
    fabriceG, if everything is connected from the power supply to the motherboard, the lights only should appear. Powering on is a different matter now. Make sure you connected the proper cables to the graphical unit. I had a problem like that in the beginning. Nothing was working because of in-proper cable management. I went to a service shop and they connected the cables properly and everything is working fine till this day
    How many watts does your power supply have? Which graphics card do you have?
  10. #10
    ROG Member Array
    Jul 2017
    Thanks for your answer!
    My PSU is an HX1200i so it's ok for the PC.
    This morning the motherboard is accepted for a third travel to the repair center !!! lol
    Is anyone with this motherboard can realize en picture or idealy video of what's happening with your mobo on the configuration below and when you press "start" on the motherboard switch please ? It will help me a lot !!!
    Thanks.
    Me :
    - i have the red light for CPU 2x8PIN disconnect -> OK
    - I have the CPU status red light -> OK
    - Have not the orange light for QLED test (BIOS led etc) -> NOK
    - Have not the OLED screen -> NOK
