Results 1 to 3 of 3
    ROG Guru: White Belt Array
    Jul 2013
    11
    101
    GL504GW GPU on Battery
    is it possible to use the nvidia card while it is on battery?
    it always jumps to the iGP when it is not plugged in.
    ROG Guru: White Belt Array TimeLion724's Avatar
    Jan 2018
    111
    You'll have to set your GPU and Power settings to max performance while running on the battery.
    Keep in mind that it will discharge very fast once you do so.
    Example: Browsing Facebook or checking your email will drain the battery down at least 1-3% once you have set everything to max performance.
    " The speed of the fallen one does not change..."
    GUIDE TO FIXING BSOD ERRORS
    Jul 2013
    11
    101
    Thanks
