q code 24 and OS cannot start
namlier
Help please. I was trying to install or boot from usb OS on asus rog crosshair hero vii , ryzen 2700x some hyperx RAM. After i choose try os without installing or install os from the menu i get black screen, and code is 24.
video attach
https://youtu.be/Xr0JHx2_GqM
15 REPLIES 15
namlier
also i was trying to install windows 7, the result was froze at first menu, when you should choose language and some locale options
error 24 is not in the BIOS q code table of the user manual found here https://dlcdnets.asus.com/pub/ASUS/mb/SocketAM4/ROG_CROSSHAIR-VII-HERO/E13835_ROG_CROSSHAIR_VII_HERO... page number appendix A-1
I think that might be showing your CPU temp as 24c
It sound like a memory error,
Check that your memory is inserted correctly and the retainer brackets are clicked into place,
Just watched your video again, make sure you have 2 sticks plugged in to DIMM SLOT 2 and SLOT 4 like this diagram
79787
79787
2 sticks, in bios i can see 16gb exactly how i expect)
yeah it was clicked,
and it is in right place as it described in installation guide, same as you bring me on the photo
ok, i will try now just with one of sticks
1 stick in dimm A2 do work as was.
Trying to switch the sticks into the same A2...
same, trying to start with one stick in B2
same...
shieeeet, i was waiting for this pc 3 months, finally all ingridients are complected, but something is bad. always the same thing with new items.
namlier wrote:
same...
have you checked that your running at default memory settings in the BIOS, 2133mhz is default.
Whats the model number of your ram ? is it on the QVL list ?
DDR4 2x8GB/ 3600 Kingston HyperX Predator RGB (HX436C17PB3AK2/16)
i didnt even change anything, in bios it says me RAM is 2400
