Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Guru: Yellow Belt Array Sverre PC Specs
    Sverre PC Specs
    MotherboardAsus Maximus X Formula
    ProcessorIntel Core i7-8700K
    Memory (part number)CMD16GX4M4B3200C15
    Graphics Card #1ROG Poseidon GeForce® GTX 1080 Ti
    Graphics Card #2ROG Poseidon GeForce® GTX 1080 Ti
    Monitor1 x Asus 27" LED FreeSync MG278Q + 2 x Benq XL2420T
    Storage #1C-drive: Samsung 960 EVO 250GB M.2 PCIe SSD
    Storage #2D-drive: Force Series LS 480GB
    CPU CoolerEK-Supremacy MX
    CaseCooler Master Cosmos C700P
    Power SupplyCorsair AX1500i
    Keyboard Corsair Gaming K95 RGB PLATINUM
    Mouse Corsair Gaming M65 Pro RGB FSP
    Headset Logitech G930
    Mouse Pad Built into the computer table
    Headset/Speakers Logitech z906
    OS Windows 10 pro 64-bit
    Network RouterZyxel P8702N
    Accessory #1 Several HDD’s 1, 2 and 3 TB
    Accessory #2 Aquaero 6xt + a lot of water cooling stuff.
    Accessory #3 UPS BlueWalker PW UPS VI 2200 SH
    Apr 2012
    140
    How do I connect several RBG fans to a Maximus X?
    I have 6 RBG fans that I would like to connect to the MB, but not sure how I should do that. The case (TT The Tower 900) does not have any ways of doing it. Can I just connect them via a 4-pin extension, will the MB be able to deliver enough power?
    [/URL]
    ROG Guru: Blue Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(3) SSD's - Samsung 960 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    45
    999
    If you have a couple fans you want running in parallel (split) from a single board header (same controlling speeds, for example two fans at the top of the case or the front of the case), you could put them on the H_AMP header, which supplies extra power for more powerful fans. Then you have 3 normal fan headers on the board. That's 5. You could also use the CPU_OPT fan header, but it will be controlling along with the CPU_FAN header so probably not recommended.
    You use the board's 5-pin EXT_FAN header if you want to plug in more fans at this point. It's meant to take the ROG fan extension board. You can buy one on Amazon or maybe directly from Asus, but there are a couple models of this out on the market so check to make sure you get the correct one for your board.
    Your last option or at least the last option I know of is to buy yourself another 3rd party fan controller hub, which is essentially what the Asus fan extension card is. Others here on the forum might have a recommendation for you on good fan controller hubs, but I don't use one so I don't want to recommend one.
    Davemon50
    Sverre PC Specs
    Apr 2012
    140
    RGB as in “how do I get the MB to control the colors”. The fans have 2 4-pin connectors, 1 for the fan speed and 1 for the color. Identical connectors ie ordinary 4-pin fan connectors.
    [/URL]
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    45
    999
    That's a different question.
    For that many fans, use a powered RGB header splitter. Make sure it's a powered splitter or you will likely overload the RGB header on your board. It's limited in amps draw, somewhere around 100 LED's but don't quote me on the exact number or amps, but 6 of those are likely too much and you'll need supplemental power.
    Davemon50
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    45
    999
    HERE is an example.
    Davemon50
    Sverre PC Specs
    Apr 2012
    140
    Ok, thanks. The example doesn’t shiw the connectors. Will it take 4-pin plugs like ordinary pwm plugs?
    [/URL]
  7. #7
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    45
    999
    That particular one has a SATA power connector and if you scroll through the pics on that site you'll see a 12V 4-pin RGB input to the hub, and up to 8 on the output. Check also Phanteks.
    Davemon50
  8. #8
    Sverre PC Specs
    Apr 2012
    140
    I saw that, but the plug isn’t a 4-pin pwm, but rather a rgb type of plug. Just wondering if I’ll throw my money away by buying one, or if it actually will take the 0lug I have (the tracks at the bottom of the plug is on the sides, not on the side and under the 3’rd pin, as pwm plugs).
    [/URL]
  9. #9
    ROG Guru: Orange Belt Array 1mluer PC Specs
    1mluer PC Specs
    MotherboardMaximus IX Apex & Maximus XI Apex's
    ProcessorI7-7700k & I9-9900k
    Memory (part number)Gskill Trident Z RGB 4266 & 3200 DC
    Graphics Card #1MSI Sea Hawk 1080 & ROG Matrix 2080 ti
    Sound Cardbuilt in for both
    MonitorSamsung 27inch & ASUS Swift PG348Q
    Storage #1Samsung 960 Pro & Samsung 970 Pro
    CPU CoolerRyuo 240 & Ryujin 360
    CaseInWin 909 Black & InWin 909 Silver
    Power SupplySeasonic 1000w Titanium & ROG Thor 1200p
    Keyboard Corsair K95 & ASUS ROG Claymore
    Mouse Logitech G902 & ASUS Gladius II Origin
    Mouse Pad Corsair MM800 & ASUS ROG Baltheus
    Headset/Speakers Bose Computer Set with Sub
    OS Windows 10 Pro all around
    Network RouterLinksys EA 9500
    Accessory #1 Corsair LL / Commander Pro & TT Riing Plus
    Accessory #2 Blue Microphone
    Feb 2017
    33
    306
    Quote Originally Posted by davemon50 View Post
    HERE is an example.
    I believe this is a 4 pin 12v RGB splitter only . The fans would connect to the fan headers on the MB. So fan control on MB and RGB control on this splitter outlined. The RGB splitter connects to the 4 pin 12v RGB header on the MB. I think it's a good choice too in this case
    BTW they make a 4 pin Fan controller too that looks very much like the RGB splitter. looks like this.
    https://www.amazon.com/XSPC-Way-PWM-...ronics&sr=1-40
    It also would be a good way to offload your fans onto this splitter and only connect the fans to the MB that you want a custom fan curve for via AI Suite.
    Inwin 909 Black RGB build
    i7-7700k
    ROG Maximus IX Apex
    1080 Sea Hawk
    InWin 909 Silver RGB build
    i9-9900k
    ROG Maximus XI Apex
    ROG Matrix 2080 ti
    Gskill TridentZ RGB DC 3200 64g
    Everything overclocked and love it.
    ROG Awesomeness !!!!
  10. #10
    Sverre PC Specs
    Apr 2012
    140
    Quote Originally Posted by 1mluer View Post
    I got that, but will it fit the RGB plugs I have on my fans? They look like ordinary PWM plugs, but with the "tracks" under pin 1 and 4, not 1 and 3 as the PWM.
    [/URL]
