Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    ROG Guru: Orange Belt Array 1mluer PC Specs
    1mluer PC Specs
    MotherboardMaximus IX Apex & Maximus XI Apex's
    ProcessorI7-7700k & I9-9900k
    Memory (part number)Gskill Trident Z RGB 4266 & 3200 DC
    Graphics Card #1MSI Sea Hawk 1080 & ROG Matrix 2080 ti
    Sound Cardbuilt in for both
    MonitorSamsung 27inch & ASUS Swift PG348Q
    Storage #1Samsung 960 Pro & Samsung 970 Pro
    CPU CoolerRyuo 240 & Ryujin 360
    CaseInWin 909 Black & InWin 909 Silver
    Power SupplySeasonic 1000w Titanium & ROG Thor 1200p
    Keyboard Corsair K95 & ASUS ROG Claymore
    Mouse Logitech G902 & ASUS Gladius II Origin
    Mouse Pad Corsair MM800 & ASUS ROG Baltheus
    Headset/Speakers Bose Computer Set with Sub
    OS Windows 10 Pro all around
    Network RouterLinksys EA 9500
    Accessory #1 Corsair LL / Commander Pro & TT Riing Plus
    Accessory #2 Blue Microphone
    Feb 2017
    33
    324
    Quote Originally Posted by Sverre View Post
    I got that, but will it fit the RGB plugs I have on my fans? They look like ordinary PWM plugs, but with the "tracks" under pin 1 and 4, not 1 and 3 as the PWM.
    Are your fans addressable RGB ? If they are addressable then you use 5v RGB Splitter.. XSPC make one of those too. In this case as I understand it, you have RGB fans with one cable standard 4pin FAN Connecter and 1 cable with RGB connectivity. They are 2 different things with 2 different circuits. They should be treated completely differently and individually.
    The 4 pin fan cable will plug into your mother board no issue. The 4 pin RGB can be one of 2 types of RGB. it might have a 4 pin connector with a blocking key only allowing 3 of the 4 pins to be used. That is 5V Addressable RGB OR it has 4 pins all available for the RGB connection.. 12V RGB. 5 or 12v RGB has to be determined in this case to use the correct splitter.
    Are there 3 wires or 4 wires used on those pins for RGB? Can you tell? Saying it only uses pins 1 and 4 doesn't sound like normal RGB connector. If it is anything other than what I described above, then they were designed for a proprietary connections like in the case of Corsair Fans. Corsair uses normal RGB technology BUT they use a different connector so they can keep you buying their supporting hardware such as commander pro. Proprietary products for common themes should go the way of the DO DO bird. That kind of thinking will ultimately kill the company. if there are 2 wires only connected then it was designed for supporting proprietary products to be used in it's connection. What brand of fan do you have ? I should of asked that from the beginning ?
    As you can see these 4 pin plugs look the same but are different. the 5v plug has 3 wires while the 12v plug has 4 wires.
    On this picture it shows a 5v RGB cable as you can tell it has 3 wires but this one shows the blocking key. Most new cables have a blocking key for the 5v RGB cable so you don't mistakenly put it into the 12V bus potentially blowing things up.
    Inwin 909 Black RGB build
    i7-7700k
    ROG Maximus IX Apex
    1080 Sea Hawk
    InWin 909 Silver RGB build
    i9-9900k
    ROG Maximus XI Apex
    ROG Matrix 2080 ti
    Gskill TridentZ RGB DC 3200 64g
    Everything overclocked and love it.
    ROG Awesomeness !!!!
  2. #12
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,462
    Is it available some adapter for converting 12V to 5V RGB LEDs...
    Example if motherboard have only 12V RGB Connector to connect 5V RGB LED.
    ASUS I think have 5V RGB LED Strips.
  3. #13
    New ROGer Array
    Dec 2018
    2
    You cannot convert 12V led's to 5V led's. If you want to run a bunch of LED's I would suggest a Corsair lighting node pro and a Corsair commander pro. You can add a lot of LED's and Fans with those combos.
    Your headers will only support so many LED's and will burn up if you do to many. However you can use external power for the LED's and still control them with your Comander pro. I soldered the +5V and ground on the led strip to Molex connector. That plugs right into a psu molex. Then the data and ground (so now you have 2 wires on the ground) went directly to the commander pro or lighting node pro. (I used both)
    I decided against using Asus Aura software since there are too many complaints about it. Hope they get that fixed.
  4. #14
    ROG Junior Member Array instyne PC Specs
    instyne PC Specs
    MotherboardROG Maximus Xl Formula
    Processori9-9900K
    Memory (part number)CMW32GX4M4C3200C16W
    Graphics Card #1Gigabyte GeForce RTX 2070 Gaming OC White 8G
    Sound CardROG SupremeFX 8-Channel HD Audio S1220
    MonitorSony XBR65X900E 65-Inch 4K Ultra HD TV
    Storage #1Crucial - P1 1 TB M.2-2280 SSD x 2
    Storage #2Western Digital - Black 4 TB 3.5" 7200RPM
    CPU CoolerTT Water 3.0 360 ARGB SYNC Premium Edition
    CaseCorsair - 680X White ATX Full Tower Case
    Power SupplyCorsair - RMx White 850 W 80+ Gold Certified Fully Modular ATX Power Supply
    Keyboard Logitech Bluetooth Multi-Device K480
    Mouse Logitech MX Anywhere 2S Wireless Mouse
    Headset/Speakers SONY RM-ANP109 Sound Bar
    OS Windows 10 Pro
    Network RouterLinksys AC4000 MU-MIMO Tri=Band Router
    Accessory #1 Corsair HD140 RGB x 5, HD120 RGB
    Accessory #2 Corsair Commander Pro, RGB Fan LED Hub
    Accessory #3 Lighting Node Pro x 2, 8 RGB Lighing Strips
    instyne's Avatar
    Oct 2012
    4
    This might be a little late but might still help someone out in the Future. This Corsair web page will show you how to do RGB fans, RGB memory, RGB led strips, RGB AIO Water Cooling, all controlled using Corsair Commander Pro, Lighting Node Pro and the RGB Fan Hub. You also need Corsair Link or Corsair I-Cue software. Zotty's CORSAIR RGB Hardware and iCUE Eco-System FAQ
