[Build Log] -ColorFalls- A RGB Wall Hanging 3D Printed Case by 8-Bit Builder
thorkon
Hello and welcome to my newest build 🙂
I've been modding for 10 years now and usually my themes are of a pixelated design. This mod is named ColorFalls as the case will be built to hang from a wall and look like it's made out of hundreds of cubes that each have a LED and will have patterned lighting effects). I will be 3D printing this case and expect to use about 9 lbs of plastic to make. Here is my CAD design so you can visualize the project.
My sponsors for this mod
Components
ASUS Prime Z390-A
ASUS GTX 2060 STRIX 6GB
ASUS ROG RYUJIN 360 AIO CPU Cooler
ASUS ROG Thor 1200W Modular RGB PSU
TEAMGROUP NIGHT HAWK Legend RGB 16gb DDR4 RAM
TEAMGROUP T-FORCE Delta RGB 250gb SSD
TEAMGROUP MS30 M.2 SATA SSD
CPU I5-9600k
Heres a few photos of my previous work:
I'll be back soon with some progress of the printing and whahtnot! Its showing it will take 2 weeks of printing time to get the main body done. I'll be back sooner than that though to show the 3D process 🙂
8 REPLIES 8
thorkon
I started the printing and got a good bit done!
This section alone takes about 2 days. Multiply this by 8 sections and you can see it takes awhile to do this project:
These squiggly lines are called supports in the 3d Printing world. It helps when you are printing hollow things, in this example, my cubes are hollow so it helping the top of the cubes having smooth finishes. It is unfortunately a waste of plastic as they get torn out when the print is done.
This is a color test with the different cube heights. Looking good!
Overview of my work desk at the moment...
thorkon
Got most of the frame done! I had to wait a little bit for plastic to come in, but I"m using 3D solutech PLA and its going pretty good.
Heres the frame pieces laying next to each other
And the pc parts in there respective places...sorta ha
Combining the sections together with glue and 3D pen welding
Small casualty when I was ripping out the support plastic sections. It will be easy to fix though since it will be covered up by the radiator of the cpu cooler.
thorkon
Boxes in position 😄
The rear bracket that will support the components. The cubes on the front are mainly for lighting, not structure support.
I messed up on the design and decided I needed these cubes out. I used my old junk soldering iron to melt out the cubes and used wire cutters and sanding to smooth it out
Asus Thor 1200w PSU
T-Force Delta RGB SSD
ASUS Prime Z390-A
Still need to do small details to fit the pieces in correctly and mount them good. Then there is also the LED wiring and whatnot. Be back soon!
DJEmir
That's a lot of work, looking good so far as do your other pieces. - DJ Emir of Denver's Best DJs
thorkon
Starting the LED work! TLDR: It did not go well...
Gluing down the led strips
All the soldering equipment
ANNNNND heres all the lights in the trash. I mixed up the pins on my molex connector since the female side needs to be backward to get 5v. I sent 12v into the leds which fried them and my arduino. Press F to pay respects to 600 LEDs 😞
Just a reference on how big this project is
thorkon
Back with a redo on the LEDs
I did the wiring slightly different so I didn't crowd the contacts on the leds
Putting the back frame on
MoBo Mount
ASUS Prime Z390-A
ASUS ROG Thor 1200W Modular RGB PSU with my 3D printed bracket
All the parts on the frame.
Next I'll be going in on the lighting and showing some of that!
thorkon
Gettting some lighting action 😄
heres a gif (if it doesn't work, There will be a link)
https://imgur.com/06VpG6I
Static image of the lights
Rearview of the new wiring setup
Getting ready to put the ASUS RYUJIN AIO in
Extremely close to being done. Just got to fill a few gaps near the components and get it mounted to the wall. I'll be back soon!
thorkon
Here it is!
This is a gif of the lighting:
https://i.imgur.com/zhxuomY.mp4
I'm trying to grow my Instagram so I can do more unique builds. Please consider giving a follow
http://instagram.com/8bitbuilder
