Results 1 to 4 of 4
    ROG Enthusiast Array TheTiesThatBind PC Specs
    Laptop (Model)Dell Inspiron 5567
    MotherboardROG MAXIMUS X HERO
    ProcessorINTEL i9-9900K
    Memory (part number)F4-3200C14D-16GTZ
    Graphics Card #1EVGA GEFORCE GTX 1080 FTW2
    MonitorASUS VG248QE
    Storage #1SAMSUNG NVME 960 EVO 250GB
    Storage #2SAMSUNG 850 EVO 250GB
    CPU CoolerCORSAIR H115i PRO RGB 280MM
    CaseNZXT H700 BLACK
    Power SupplyCORSAIR RM750X V2
    Keyboard CORSAIR K70 MK2 RAPIDFIRE
    Mouse RAZER DEATHADDER ELITE
    Headset HYPERX CLOUD REVOLVER
    Mouse Pad RAZER GOLIATHUS CONTROL EXTENDED
    OS WINDOWS 10 HOME X64
    Accessory #1 SAMSUNG 860 EVO 500GB
    Accessory #2 WD CAVIAR BLACK 1TB
    Accessory #3 CORSAIR ML120/140 RGB PRO
    TheTiesThatBind's Avatar
    Sep 2018
    43
    [HELP] Overclocking 9900K on Maximus X Hero
    So I’m trying to OC my 9900K on Maximus X Hero but I face some difficulties. Even though I manage to pass Intel Burn Test with 10 Loop at Very High with 1.24V @ 5GHz I’m getting BSODs on RealBench. Any ideas why/what should I try next?
    I just put 50 on the multiplier, 1.24V Manual volt and lift any power limit. And of course enabled XMP and Disabled C-States*
    MonitorASUS VG248QE
    CaseNZXT H700 BLACK
    Sep 2018
    43
    So as of I now I’m still not able to pass RealBench at 1.24, 1.26V Stress Test but I’m able to pass IBT.
    I tried 1.29 and 1.28 Volt and had no trouble passing RealBench but VRM Temp sensor in HWINFO64 peaked at 101C.
    I also tried 4.9 @ 1.24V both tests passed and also I had both tests successfully passed with 4.9 @ 1.20V so far.
    I will try even lower see where it lands. But why I pass IBT @ 1.24 and getting BSODs at RealBench in the first few seconds at 5G @ 1.24V?*
    ROG Guru: Brown Belt Array NemesisChild PC Specs
    MotherboardASUS Maximus X Hero (WI-FI AC)
    ProcessorIntel i7 8700K
    Memory (part number)G.Skill F4-3600C16D-16GTZR
    Graphics Card #1Nvidia GTX 1070 Ti FE
    Graphics Card #2Nvidia GTX 1070 Ti FE
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 970 PRO 512GB NVMe M.2
    Storage #2WD Black 2TB 7200 RPM 64MB Cache
    CPU CoolerNZXT Kraken X42
    CaseCooler Master HAF 932 Advanced
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G703 Wireless
    Headset Logitech G Pro
    Mouse Pad SteelSeries
    OS Windows 10 Home x64 (UEFI)
    Network RouterLinksys WRT1900AC
    NemesisChild's Avatar
    Sep 2011
    89
    1,773
    Quote Originally Posted by TheTiesThatBind View Post
    IBT basically stresses the CPU and not much else.
    RB is more realistic in that it stresses the entire system: CPU, graphic card, and memory.
    Intel i7 8700K@ 5.2GHz (Delidded)
    ASUS Maximus X Hero (Bios 1801)
    NZXT Kraken X42
    G.Skill TridentZ@ 4000MHz CL16 2x8GB
    SLI: 2x Nvidia GTX 1070 Ti FE@ 2025/2025MHz
    OS: Samsung 970 PRO 512GB NVMe M.2
    Storage: Samsung 960 EVO 500GB NVMe M.2
    Storage: 2x Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 2TB
    ROG Guru: White Belt Array HisEvilness PC Specs
    MotherboardASUS ROG Maximus Hero XI
    ProcessorIntel i7 8086k
    Memory (part number)32gb G.Skill TrridentZ RGB
    Graphics Card #1ASUS ROG 1080ti
    MonitorAcer Predator 27Inch/Iiyama G-Master GE2488HS-B2/ProLite E2474HDS
    Storage #1Samsung 960 EVO
    Storage #2Samsung 860 EVO x 2
    CPU CoolerCorsair 150i Pro
    CaseLian-Li Dynamic
    Power SupplyRMx 850
    Keyboard Roccat Vulcan 120 AIMO
    Mouse Roccat Kone AIMO
    Headset Sennheiser 58X
    OS Win 10 Pro 64
    Network RouterASUS RT-N18U
    HisEvilness's Avatar
    May 2017
    80
    Ensure you test with none AVX loads as well, and make use of an AVX offset for the tasks that would need it. Gaming etc does not need AVX thus you can get higher clocks for that vs rendering that does need AVX.
