Results 1 to 5 of 5
    ROG Guru: Yellow Belt Array kshafe777 PC Specs
    kshafe777 PC Specs
    MotherboardMaximus XI Formula
    Processor9900k
    Memory (part number)Trident Z RGB 64 GB 3600 speed
    Graphics Card #1EVGA RTX 2080Ti FTW3 OC
    Graphics Card #2EVGA RTX 2080Ti FTW3 OC
    MonitorASUS PG27UQ
    Storage #1Samsung 970 EVO Plus M.2 1TB
    Storage #2Samsung 970 EVO Plus M.2 1TB
    CPU CoolerHeatkiller nickel
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1200i
    Keyboard G.Skill KM780 RGB Cherry Mx
    Mouse Roccat LEADR
    Headset AKG K7XX
    Headset/Speakers Razer Nomo Pro
    OS 10 pro
    Network RouterRaptor
    kshafe777's Avatar
    Jan 2014
    180
    my first sli setup.. using Maximus XI Formula. pcie question
    so, when i use two gpu's in sli, doe the max xi formula limit both to x8 now? or are they both x16 still? it seems to be x8 on both cards. any help would be appreciated. thanks
    "Better to try and Fail, then not try at all" ~ Michael Jordan
    favorite YouTuber - KDSTech - https://www.youtube.com/channel/UCz0...iWiBx3v6CNR3yw
    ROG Guru: Green Belt Array Phillyflyer's Avatar
    Mar 2012
    30
    536
    Quote Originally Posted by kshafe777 View Post
    Cards will run 8x
    Asus ROG Maximus XI EXTREME
    Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
    XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
    Swiftech Drive II / Swiftech MCP35X Pump
    Enermax Platimax 1200 Watt Power Supply
    32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
    MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
    (5)Samsung 840 Pro 128 GB In Raid 0
    (2) WD 1TB Black Edition
    Corsair 900 D
    kshafe777 PC Specs
    Processor9900k
    MonitorASUS PG27UQ
    Mouse Roccat LEADR
    Headset AKG K7XX
    OS 10 pro
    kshafe777's Avatar
    Jan 2014
    180
    thanks. is this limitation caused by z390? by the 9900k? just becuase x16 for both lanes isn't needed? curious. thanks!
    Mar 2012
    30
    536
    Yes...to run sli 16x you would need to switch to another platform ie: x299
    Corsair 900 D
    ROG Member Array
    Nov 2014
    13
    Correct me if I'm wrong, but I don't think there any difference given that even a 2080 ti can't saturate 8 PCIE 3.0 lanes. I recall reading this when I was looking into getting my Formula XI and a pair of 2080 TI's:
    https://www.gamersnexus.net/guides/3...idth-x16-vs-x8
