Results 1 to 8 of 8
    New ROGer Array
    Apr 2019
    2
    How to turn off Rampage Extreme VI Omega onboard lights
    How would one turn off the rgb lights and lcd on the ASUS Rampage Extreme VI Omega motherboard when the computer has been powered off with out turning off the power supply or plunging the pc?
    Thank you for any help you can provide.
    ROG Guru: Orange Belt Array 1mluer PC Specs
    1mluer PC Specs
    MotherboardMaximus IX Apex & Maximus XI Apex's
    ProcessorI7-7700k & I9-9900k
    Memory (part number)Gskill Trident Z RGB 4266 & 3200 DC
    Graphics Card #1MSI Sea Hawk 1080 & ROG Matrix 2080 ti
    Sound Cardbuilt in for both
    MonitorSamsung 27inch & ASUS Swift PG348Q
    Storage #1Samsung 960 Pro & Samsung 970 Pro
    CPU CoolerRyuo 240 & Ryujin 360
    CaseInWin 909 Black & InWin 909 Silver
    Power SupplySeasonic 1000w Titanium & ROG Thor 1200p
    Keyboard Corsair K95 & ASUS ROG Claymore
    Mouse Logitech G902 & ASUS Gladius II Origin
    Mouse Pad Corsair MM800 & ASUS ROG Baltheus
    Headset/Speakers Bose Computer Set with Sub
    OS Windows 10 Pro all around
    Network RouterLinksys EA 9500
    Accessory #1 Corsair LL / Commander Pro & TT Riing Plus
    Accessory #2 Blue Microphone
    Feb 2017
    33
    320
    Look in the aura sync software.. look for the sync at shutdown tab and you can select off. That should do it..
    Inwin 909 Black RGB build
    i7-7700k
    ROG Maximus IX Apex
    1080 Sea Hawk
    InWin 909 Silver RGB build
    i9-9900k
    ROG Maximus XI Apex
    ROG Matrix 2080 ti
    Gskill TridentZ RGB DC 3200 64g
    Everything overclocked and love it.
    ROG Awesomeness !!!!
    New ROGer Array
    Apr 2019
    2
    How to turn motherboard LCD badge off on Omega
    Hi 1mluer,
    That worked for turning off the rgb board lights. Would you know of a way to turn off the motherboard LCD badge?
    Thank you!
    1mluer PC Specs
    Feb 2017
    33
    320
    You know there might be settings in bios you can do. I am doing this from memory but on my board there is an area called ROG effects. You can turn off the lights all together there but to be honest I haven't tried anything else probably because my current APEX doesn't have an LCD display. There might be selection there if you do have a display. I am going to go into bios and see if I can be more specific.. Give it a try though.
    UPDATE:
    It's not ROG effects.. It's under "Advanced" Tab then go down to "Onboard Device Configuration" if you have it for your board.
    i7-7700k
    ROG Maximus IX Apex
    1080 Sea Hawk
    i9-9900k
    ROG Maximus XI Apex
    ROG Matrix 2080 ti
    1mluer PC Specs
    Feb 2017
    33
    320
    My BIOS section is under "Advanced" tab then down to "Onboard Device Configuration". I can do a lot of things there including turning off the light and effects after shutdown too.
    See if it's there ?
    I think if you do both areas it has all the basis covered unless you don't have this area of bios settings
    i7-7700k
    ROG Maximus IX Apex
    1080 Sea Hawk
    i9-9900k
    ROG Maximus XI Apex
    ROG Matrix 2080 ti
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,801
    Quote Originally Posted by Donzi View Post
    Hi 1mluer,
    Thank you!
    If you're referring to the OLED Display, install LiveDash from the Drivers & Utilities page.
  7. #7
    ROG Member Array paru055 PC Specs
    paru055 PC Specs
    MotherboardAsus Rog Ramapage Extreme vi
    ProcessorIntel i9 7900x
    Memory (part number)Corsair Vengence Pro 2666 64 GB
    Graphics Card #1Asus Rog Strix 1080ti 11GB
    MonitorSamsung syncmaster 2000
    Storage #1SSD NVME 1TB samsung
    Storage #212 TB HDD Segate
    CPU CoolerAsus Rog Ryo 240
    CaseCoolermaster C700m Cosmos
    Power SupplyAsus ROG Thor 850W
    Keyboard Asus ROG Claymore Core
    Mouse Asus ROG Pugio
    Headset Asus ROG DELTA RGB
    Mouse Pad ASUS ROG Balteuis QI
    OS WINDOWS 10
    Network RouterAsus ROG Rapture GT-AX11000
    Accessory #1 Lian LI RGB Strimmer pin cable
    Accessory #2 Lametric Subscriber Counter
    Accessory #3 Corsair ST100 Headphone Stand RGB
    Mar 2019
    18
    Quote Originally Posted by Silent Scone@ASUS View Post
    hi i installed live dash and not showing my motherboard, only showing my AIO coller Ryuo 240
  8. #8
    1mluer PC Specs
    Feb 2017
    33
    320
    Quote Originally Posted by paru055 View Post
    I would go to the site and check the utilities for your motherboard. go to the main site > Support page > enter your motherboard > go to utilities and download the very latest Live Dash listed for your motherboard. uninstall the old version of livedash, reboot and then reinstall livedash.
    Let me know if that worked.
    i7-7700k
    ROG Maximus IX Apex
    1080 Sea Hawk
    i9-9900k
    ROG Maximus XI Apex
    ROG Matrix 2080 ti
Tags for this Thread
